Old 04-03-2019, 09:18 AM
Norbertools Norbertools is offline
Default Courser-line should be automatically tell the transport where to start?!
I want to start play where the courser is when using a shuttle wheel WITHOUT having to extra grab the mouse to click the timeline for a starting point for the playback. Like it is in every other DAW.
And no, I'm NOT talking about Pre-Roll, Count-in, Dynamic Transport, Link Timeline and Edit Selection, and Insertion Follows Playback.
The courser-line should be automatically tell the transport where to start. I'm going slightly nuts about it. Is there a way?
kind regards
Old 04-03-2019, 09:55 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Courser-line should be automatically tell the transport where to start?!
Which shuttle wheel are you using? Are you using HUI?
I use a Presonus Faderport and when I scroll back or forwards to a particular spot on the timeline it plays from that spot.
Will
System Details
Old 04-03-2019, 10:14 AM
contour shuttle pro v2
Old 04-16-2019, 06:54 AM
There is a preference for "Edit Insertion Follows Scrub/Shuttle". If this ism checked, and Link Timeline and Edit Selection is on, then it should behave the way you want.
Scott Gatteño
Old 04-16-2019, 07:59 AM
Thanks for the response, but it doesn't work either.
How to make S6 automatically access the Xmon on start up vudoo Avid S4/S6 5 09-24-2020 12:51 PM
Using Transport to start a VI paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-24-2010 07:12 AM
Strike -How to start it automatically when hit play ? Blues Bird Virtual Instruments 1 04-04-2010 01:00 PM
Track input line Mutes itself Automatically, Why? DarylBham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-06-2006 09:30 AM
Mbox PT LE 6.7 problem: Unreceptive Courser andyloflin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-14-2005 12:59 PM
