Old 10-18-2019, 09:48 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Syncing pro tools hd and 3 camera live video shoot
Originally Posted by Philthy View Post
Sorry to go off topic, but I'm curious why two digital disc-based recording systems are still doing things like drifting apart in time? We're dealing with sampling rates of tens of thousands to a second, yet systems aren't independently keeping good enough time? How big a problem is this- say, what kind of drift might the OP expect over a 40 minute program? I've never met drift that I couldn't fix by correctly matching frame rates, but when I'm worried about sync it's usually just 3-minute videos- too short a time to notice the problem?
As Kelsey already mentioned, if you DON'T sync your audio to the video sync generator, your audio will drift over time... guaranteed. If you can have timecode going everywhere, that's good for keeping everything at the same 'location' when you mix, but if you don't have sync then timecode won't matter.
Having one MASTER CLOCK tells all devices "LOOK AT ME!! My signal of 59.94 Hz is what EVERYONE references to." Forty eight thousand samples per second where one second equals 59.94. Thirty frames (or sixty) of video where one second equals 59.94.
If you can only get one source from video, ALWAYS take video sync, and it doesn't have to be from a black burst generator... you can always run a video feed to the Sync IO and plug it into the video input, NOT video reference. The video carries the same reference signal embedded as black burst would generate.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 02-06-2021, 10:37 AM
diego.biagioni diego.biagioni is offline
Hello everyone on this topic,
So to recap: I would connect GenLoc out of the camera (our is a Panasonic AG-HPX371) into Sync HD Video in or Video Ref ?
And set the camera as Master Timecode and Sync Hd from Video sync source?
then, do I still need to connect the Sync HD video output to the Timecode In of the camera?
Thank you
Lily - the world's first throw-and-shoot camera unkJE Post - Surround - Video 4 02-25-2016 07:04 PM
Fashion shoot camera sounds in 2011? reichman Post - Surround - Video 3 10-13-2011 06:47 AM
PT9, Digi002 and Synching to live video shoot Nick Melander macOS 3 07-16-2011 08:49 AM
LIVE REC W/ PT LE AND MULTI CAMERA SHOOT? Ken P Tips & Tricks 16 06-07-2005 08:59 AM
syncing Sony VX2000 digital video camera w/001? GrahamCA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-25-2002 08:37 PM
