Old 04-16-2007, 04:47 AM
Tomio Broman Tomio Broman is offline
Default HP xw9300 and MIDI i/o still doesn\'t work
Is anybody using the DigiDesign MIDI i/o with the HP xw9300 combination?
I never got it to work, even with the latest drivers.
Someone from Digi said that it was a compatibility problem with the HP xw9300.
Everytime time I try set the PRE i/o to read from the MIDI i/o channel 1 in the Setup / Peripherals,
an error would appear saying that ProTools lost communciation with the MIDI i/o.
So I would have to end up disabling the MIDI i/o in ProTools.
I'm on ProTools 7.3.1 cs2 HD3 Accel.
The MIDI i/o is currently powered from a USB hub which is powered from an AC adapter.
My next step was to power the MIDI i/o directly with an AC adapter, but wasn't sure what kind to get. Does anyone have a suggestion?
Thanks
Tomio
Old 04-18-2007, 07:30 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: HP xw9300 and MIDI i/o still doesn\'t work
I have no idea if this will help with the problem or not (I'm not a tech), but here is the spec for the DC power adapter from the MIDI I/O Guide:
Alternate Power
If you want to use the MIDI I/O without connecting it to your computer, you can use any 9–12 Volt DC power adapter, 500 mA (Tip +/Ring –) for power. When used in this way, the MIDI I/O will only function in MIDI Thru mode.
Typically, you will not need to use an external power supply when the MIDI I/O is connected to your computer, since the MIDI I/O is powered over USB from your computer. However, if you want to use the MIDI I/O in MIDI Thru mode without a computer, or if it is connected to an unpowered USB hub, you will need to use an external power supply.
Do not attempt to use one or more unpowered MIDI I/O units on an unpowered USB hub.
Administrator
ERROR - 6084 HP xw9300 Metro33196 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-28-2008 11:32 AM
OT xw9300 Only sees 2 gigs on ram XP Pro Brandonx1 Pro Tools TDM Systems (Win) 2 09-24-2006 03:33 PM
digi 001 midi ports + OMS . Cant get midi to work voltech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2006 12:32 PM
xw9300 and MIDI i/o Tomio Broman Pro Tools TDM Systems (Win) 0 06-20-2006 03:49 AM
How do you work with MIDI in PT? Jim Clark MIDI 8 10-20-2001 08:20 AM
