Old 04-01-2007, 12:32 AM
steve at Your Heaven steve at Your Heaven is offline
Default Can\'t change record folder
I have moved Sessions to a new drive, deleted them from the old drive. I opened a session on the new drive, and reset the existing file locations using the Digibase 'manual' method (I choose the correct drive and folder so it doesn't spend 20 minutes searching through drives and folders).
All existing tracks then show the old recording path in the 'Assign Drive' dialog, and greyed out - they cannot be changed as such. Recorded files from these tracks end up in a newly created folder on the old drive's root.
So far, the only workaround I have found is to duplicate these tracks, delete the old ones, and then rename the new ones with the original names I chose. These new tracks show up in the 'Assign Drive' dialog just where I would expect them, in the session folder on the new drive.
All the drives are properly set for recording (it does work with the correct drive after the above procedure).
Any help with the unchangeable/'greyed-out' thing? And, is there a simple way to move from one place to another without having to go through this nonesense? Did Digidesign really create their 'clever' file system without the sense to at least look in a session's current folder for the session's files before going on a complex and time consuming relocation procedure?
Thanks,
Steve
steve
Your Heaven
Old 04-01-2007, 08:49 PM
tea4chew tea4chew is offline
Default Re: Can\'t change record folder
Hi Steve,
Forgive me if I am misunderstanding your problem. On my system I can just drag the session folder on to a new drive (which copies it), then when I open it at the new location, all existing media has the correct path to the new drive, so protools doesn't need to go through the relink process. I then just update "disk allocation" for all tracks in the "setup" menu, and all new media also ends up in the new location.
Lien
Old 04-04-2007, 12:50 AM
That was the case for me until I upgraded to 6.7, which has ever since asked me to find the files (and now, apparently, 6.9.3, which also won't let me change the paths for existing tracks).
Does anyone know if there is some setting I don't know about that determines this behavior?
steve
Your Heaven
cannot change transfer to record in workspace awaiting instruction General Discussion 2 08-14-2009 08:42 AM
Altiverb-change impulse response folder cinetj Post - Surround - Video 2 08-04-2008 03:08 PM
Change or set new audio files folder smc917 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-06-2004 08:07 AM
PT 6.4 and the Plug-ins Folder - how to change? nedorama 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-21-2004 07:19 AM
DAE Folder can't change memory aprim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-18-2003 10:30 AM
