Old 03-28-2007, 10:10 AM
steve at Your Heaven steve at Your Heaven is offline
Default asio and wav drivers not showing up in vegas
Using vegas 4.0 for years, along with PTools tdm 6.7, asio and wav drivers showed up in vegas as expected and worked fine.
Installed 6.9.1, then pt693cs4_26664. No asio or wave drivers appear at all, even if I remove the usb soundcard.
Any thoughts or experience with this?
steve
Your Heaven
Old 04-01-2007, 12:32 PM
Greg M Greg M is offline
Default Re: asio and wav drivers not showing up in vegas
Steve,
I currently use Vegas 7 and both ASIO and Wave drivers show as available with the Digi002 rack (PTLE 7.3.1cs2). I know its not TDM or Vegas 4. It might be worth a try to re-install Vegas and the ASIO and wave drivers. Also, Vegas has come a long way since version 4. Sony usually has an upgrade path from any older version to the most recent for under $200.
Hope this helps a little,
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 .
003 Drivers not showing up in Device Manager zedhed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-25-2014 03:46 PM
ASIO in PT8 not showing up Superclock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-03-2009 04:17 PM
ASIO Drivers for OS 9.2 quaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-29-2004 01:13 PM
ASIO drivers for PC!!!!! QuikDraw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 05-11-2002 05:17 AM
ASIO Drivers for PC TimWay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-27-2000 11:07 AM
