Problem with 2 mono plugins on a stereo track
On a stereo Aux input track, I insert 2 mono plugins. On one of the plugins I set it to "L" and on the other plugin I set it to "R" Everything works fine.
However, if I click on the insert point of the plugin that is set to "R" it flashes and changes to "L" If I close the "R" plugin, (not delete it from the insert point, it is still inserted) and then open it again, it has changed from "R" to "L" At first I thought this was a plugin problem. However, it does this with my Waves plugins as well as my McDSP plugins. How can I fix this? I want to be able to use two independent plugins on a stereo track. Thanks, -Andres |
Re: Problem with 2 mono plugins on a stereo track
You could create 2 MONO Aux and Pan one left and one right and have a plug on each. You can still use a stereo send from the tracks which would feed into both plugins equally. Or if you want the Plugin outputs to be centred then use 2 stereo Aux in the same way.. All the best, Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
BIG D,
Thanks for the response. I had not thought of using 2 separate mono tracks--that certainly is a good work-around for the problem. -Andres |
making mono track into stereo or double mono in PT7LE | VeganMuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-02-2012 05:36 AM |
Conver stereo track to SINGLE mono track | markolone | Pro Tools M-Powered (Win) | 1 | 07-30-2010 07:09 PM |
Stereo linking mono plugins? | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-31-2008 07:45 AM |
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 06-26-2002 03:21 PM |
can you not copy automation data from a mono track to a stereo track? | Felix | Tips & Tricks | 5 | 04-09-2002 06:32 PM |
