Old 03-27-2007, 11:55 AM
Andres Gonzalez Andres Gonzalez is offline
Default Problem with 2 mono plugins on a stereo track
On a stereo Aux input track, I insert 2 mono plugins. On one of the plugins I set it to "L" and on the other plugin I set it to "R" Everything works fine.
However, if I click on the insert point of the plugin that is set to "R" it flashes and changes to "L"
If I close the "R" plugin, (not delete it from the insert point, it is still inserted) and then open it again, it has changed from "R" to "L"
At first I thought this was a plugin problem. However, it does this with my Waves plugins as well as my McDSP plugins.
How can I fix this? I want to be able to use two independent plugins on a stereo track.
Thanks,
-Andres
Old 03-27-2007, 05:54 PM
BIG D BIG D is offline
Default Re: Problem with 2 mono plugins on a stereo track
You could create 2 MONO Aux and Pan one left and one right and have a plug on each. You can still use a stereo send from the tracks which would feed into both plugins equally.
Or if you want the Plugin outputs to be centred then use 2 stereo Aux in the same way..
All the best,
Big D
INTEL QUAD XEON
INTEL S5000XVN serverboard
4 gig Fully Buffered Ram (About to add more)
3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green
NVIDIA Geforce 7300le,
Command 8,HD2,192,Massive Pack 4
Windows 7 64 bit PTHD 9
Old 03-28-2007, 08:32 AM
BIG D,
Thanks for the response. I had not thought of using 2 separate mono tracks--that certainly is a good work-around for the problem.
-Andres
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
Conver stereo track to SINGLE mono track markolone Pro Tools M-Powered (Win) 1 07-30-2010 07:09 PM
Stereo linking mono plugins? Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-31-2008 07:45 AM
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 06-26-2002 03:21 PM
can you not copy automation data from a mono track to a stereo track? Felix Tips & Tricks 5 04-09-2002 06:32 PM
