NO SOUND after starting Eleven Rack
Every now and then my Eleven rack was muted after starting.
I use my Eleven Rack mainly for live gigs and there is no sound. Worst case! This required me more than a year to find help and a "permanent" solution. You start your Eleven Rack, have your speaker or amp or headphone plugged and switched on, but the Eleven Rack gives you no sound at all. Just a small summing. Sometime it helped to reload all rigs from the computer, but this is no real solution. The best workaround so far and it was always working until today. JUST CHANGE THE SAMPLING RATE/CLOCK SOURCE TEMPORARILY AND YOUR WILL GET YOUR SOUND BACK! Step-by-step: 1. Press the EDIT/BACK button for 2 seconds to get into user options. 2. Scroll to Clock Source and choose it 3. Change clock source e.g. from Int 44.1k to Int 88.2k and wait 2 seconds 4. Switch clock source back to original value Your sound will be back! Hope this helps you, too. Regards, Mathias |
Re: NO SOUND after starting or plugin Eleven Rack
Same can be applied if sound is lost after plugin USB device.
Starting to like this Eleven Rack I just bought! | J.LaGrassa | Eleven Rack | 11 | 10-21-2014 04:52 AM |
no sound with mic in eleven rack? | baldy5000 | Eleven Rack | 27 | 01-12-2014 02:36 PM |
No sound on eleven rack | JensBC | Eleven Rack | 3 | 06-05-2012 05:42 AM |
Eleven Rack No Sound! | Ph.D | Eleven Rack | 40 | 07-26-2011 09:38 PM |
