Old 11-25-2013, 03:06 PM
brickroadstudio brickroadstudio is offline
Default Need upgrade to PT 10HD only
Need some help here, can't get an answer from AVID.
I am currently on v9 HD.
I need to go to v10 because I am also running logic using my 192. Logic 10 is now requiring a firmware update of the native card to work. So, with the update Logic works, but then PT won't and I have to downgrade it.
I do not want to pay $1,000 to go to 11 which doesn't support my 192, I would like to only pay to go to HD 10.
Can anyone help?
Old 11-25-2013, 03:14 PM
peterle peterle is offline
Default Re: Need upgrade to PT 10HD only
---when you upgrade to 11HD it includes a 10HD Licence..
foley artist , soundeditor
Old 11-25-2013, 03:16 PM
I am aware of this. But, why should I have to buy 11 which I can't use since it doesn't support my hardware? I wish to only purchase 10.
Old 11-25-2013, 04:04 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
The upgrades to Pro Tools HD 10 from 7 and 8 are more expensive:
Pro Tools 10 HD Upgrade From 7/8
The upgrade from PTHD 9 to 10 is the upgrade to PTHD 10/11
I understand your point, but those are the only upgrades available that do not involve a hardware exchange.
Bruce Paine
System Details
Old 11-25-2013, 05:06 PM
So whats the story, will my 192 work with 11 or no?
Old 11-25-2013, 05:26 PM
The TDM cards your 192 connects to won't work in PT11. Sure when you upgrade to 11 you also get PT 10 but there's nothing that says you have to load PT11. Although you could load 11 and run the audio out your Mac's output.
Jack
QAPLA!
Old 11-25-2013, 06:52 PM
Admin Emeritus
You have an HD Native system, correct?
Not officially supported (not tested) as it says in the PTHD 11 System Requirements
But a quick check in the Pro Tools HDX and HD Native forum found this thread:
PT 11, HD Native and blue interfaces
Also, you mentioned firmware problems. See this sticky in the HD Native forum:
Firmware related errors and resolutions for HD|Native Hardware
Bruce Paine
System Details
Old 11-25-2013, 08:33 PM
Yeah, running Native now, sold all the TDM when I went to 9...
Thanks a lot for this.
Old 12-03-2013, 03:00 PM
Admin Emeritus
Can you check the exact version number of your CoreAudio Manager application? It should be located in one of these locations:
Macintosh HD/Applications/Avid/Pro Tools/Avid CoreAudio Manager.app
or
Macintosh HD/Applications/Digidesign/Pro Tools/Avid CoreAudio Manager.app
(I can't remember if it was named Avid or Digidesign in Pro Tools 9, I'm not a tech)
Also the version on this file:
Macintosh HD/Library/Audio/Plug-Ins/HAL/Avid CoreAudio.plugin
Thanks, that will help us figure out if Logic is using a different version than Pro Tools.
Bruce Paine
System Details
Old 12-17-2013, 02:28 PM
myke2242's Avatar
myke2242 myke2242 is offline
or
i recently tried to upgrade and was meet with a payment (paypal) loop that got me no where. i just gave up.
9HD to 10HD upgrade needed Artysan Buy & Sell 0 07-09-2013 07:26 AM
10 to 10HD upgrade Alex TCH Pro Tools 10 10 02-15-2013 12:50 PM
upgrade PT 10 to PT 10HD bennyx75 Pro Tools 10 9 10-05-2012 03:45 PM
Protools 10HD upgrade to from 9 is 999.99 ..... WHY T_S_Harris Pro Tools 10 561 11-17-2011 08:01 PM
2 questions about 10HD upgrade. IO Composer Pro Tools 10 9 10-22-2011 03:29 PM
