  #41
Old 03-17-2010, 06:06 PM
GNA
Guest
Posts: n/a
Default Re: My Axiom Template for Pro Tools 8
I just purchased an Axiom 49 and am quite disappointed that it does not have presets for Pro Tools. The salesperson assured me that it should be easy to map controls in Pro Tools and various plugins, and he figured that there were Pro Tools presets since he uses an Axiom 49 with Ableton. But clearly M-Audio has emphasized Ableton at the expense of Pro Tools, because there are no presets for the latter, and there appears to be no rhyme or reason to the controls matching up with anything in Pro Tools 8.03 or any of the plugins it includes.
Granted, I'm a beginner when it comes to using a MIDI controller to manipulate software controls, but I can't believe that a product like this would not have at least reasonable out-of-the-box functionality with the leading DAW on the market.
I know that someone has posted a template here, but it looks like it has limitations. Isn't there any way for me to quickly make sense of the MIDI controllers and assign them to what I want them to control in my DAW and plugins?
  #42
Old 04-06-2010, 09:10 AM
Mike Deepintheghetto Mike Deepintheghetto is offline
I agree.... can't seem to get the pads to work on my Axiom 25. You would think a Pro Tools preset from M-Audio would get you started. So much content on this forum, I'm sure my answer is here somewhere?
The Axiom works in my PT sessions, but not the pads. I use Addictive Drums. Should I be using MIDI in/out from the Axiom to Mbox2?
Thanks,
Mike
Windows XP SP2
Pro Tools LE 8.0 cs2
Mbox 2
Axiom 25 (usb into PC)
  #43
Old 04-13-2010, 07:46 PM
Willosy Willosy is offline
I'm not sure why M-Audio (Avid) don't release a preset for PT8. Especially seeing as how PT8 and Axiom are all Avid now and we are all using 2 X Avid products.
I still can't get my Axion 61 non-Pro to work effectively with PT.
Giddy up Avid, better support please.
  #44
Old 05-06-2010, 09:33 AM
Strebor24 Strebor24 is offline
I don't get why you needed to create this patch... my Axiom Pro did all that right out of the box.
Shuttle PC, XP Home SP 3, Core 2 duo 3.16 GHz, 4gb PC6400, 500gb SATA 3G HD, Mbox2 pro., Pro Tools 8.
  #45
Old 05-09-2010, 03:21 AM
gruddlebug gruddlebug is offline
Because it's for an Axiom, yours is an Axiom PRO
Cheers
evs
  #46
Old 07-01-2010, 09:47 AM
fso fso is offline
thank you very much for this template... i will try this out... if i run into trouble i let you know
  #47
Old 07-03-2010, 09:13 AM
autodidactic autodidactic is offline
Originally Posted by elvisnixon View Post
FYI, i was able to get this profile to work on an Axiom 61 only after replacing this commencing section of the xml config file with text from a legitimate axiom 61 xml config file.
Here is the section I replaced (commences at very start of code):
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>preset</key><dict>
<key>name</key><string>Axiom 49</string>
<key>created</key><string>9:18:1:4:2009</string>
<key>PID</key><integer>409</integer>
<key>VID</key><integer>1891</integer>
<key>Group ID</key><integer>17</integer>
<key>unique id</key><integer>2829</integer>
<key>read only</key><false/>
<key>ROM</key><false/>
<key>presets</key><array>
<dict>
I replaced it with this:
<dict>
<key>name</key><string>Axiom 61 1</string>
<key>created</key><string>26:0:10:9:2009</string>
<key>PID</key><integer>410</integer>
<key>unique id</key><integer>12093</integer>
<dict>
I was just about to post about altering the XML file when I see you beat me to it. I'll add to your post that the only two lines that need to be altered are:
On the first line, you just change the bold text to whatever you want to call the preset. On the second line, the bold text is the device ID. 409 represents the Axiom 49 and I've found that 410 is for the Axiom 61. I am assuming that 408 will probably be for the Axiom 25. Once you change the lines in a text editor, Enigma should show the proper keyboard type in the graphic editor screen (you may need to restart Enigma and import the preset again). If anybody is having trouble with Enigma communicating with your non pro Axiom keyboard, try changing the device ID to match your keyboard type. I had that problem initially but after doing a factory reset and altering the xml file I got it to work.
I just finished pulling this off so I will see how well everything is working. So far so good though. Much gratitude to the OP for posting this and saving us Axiom users a lot of trouble! BTW, on the download page, the file name is in quotes. Get rid of those once you download the file.
Hope this helps some people.
Mac Mini
OSX 10.10.5
Behringer XR18
  #48
Old 07-28-2010, 12:49 PM
rpossum rpossum is offline
Thanks for this!
NOTE:
I was only able to get this working with MIDI Machine Control (Master) enabled and (Slave) disabled. Took me forever to figure that out!
Cheers
Russell
  #49
Old 08-05-2010, 12:03 AM
Prody67 Prody67 is offline
Hi gruddlebug,
You're a star!!
I installed your template and it works like a dream...
Thanks man ;o)
My Setup:
PC: Win XP SP3
CPU: AMD Athlon II x4 Quad
RAM : 4gb
DAW: PT 8.0.4 and Instrument Expansion Pack
Kit: mBox 2, Axiom 49
  #50
Old 09-02-2010, 10:58 PM
MMAKINMITCH MMAKINMITCH is offline
Angry Re: My Axiom Template for Pro Tools 8
Processor : AMD Athlon 64 X2 5200+ @ 2700 MHz
Hard Disk : ST3808110AS (80 GB)
Hard Disk : WDC (74 GB)
Hard Disk : Seagate (250 GB)
Physical Memory : 4096 MB (2 x 2048 DDR2-SDRAM )
Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 3
Video Card : ATI Radeon HD 2400 XT
Monitor Type : Acer P201W - 20 inches
I have AXIOM 61,I tried to up load your settings in egnigma software and it crashes on me so please if you can give me more details on how i should up load your file???
Novation Launchpad Pro Tools Edit template frabo Tips & Tricks 8 08-31-2016 01:11 PM
Eleven Rack Pro Tools 11 template is blank / broken sbaures Eleven Rack 10 01-29-2014 11:10 AM
Tested out a Template, now Pro Tools is ruined! ThirteenInvitations macOS 5 09-17-2013 07:24 AM
A little help please = Axiom 49 & Pro Tools 8 LE Bongo5HH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-15-2009 03:03 PM
Have Pro Tools Automatically Open Template elankf1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-13-2006 02:50 PM
