Old 06-15-2019, 05:43 AM
Cryos's Avatar
Cryos Cryos is offline
Default Pro tools control question
I'm still running 18.xxx last version. I've been seeing and hearing about all kinds of bugs with the new eucon software; have the issues been resolved ? Until I know for certain I'm in no hurry to download it update my iPad or the app or even protools for that matter.
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 06-15-2019, 02:06 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Re: Pro tools control question
I just update EuControl here yesterday seems a lot more stable sync-wise than the last version. Run it for 6+ hours yesterday without issues.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 06-15-2019, 03:04 PM
Cryos's Avatar
Are you seeing any bugs in protools like plugins closing by themselves etc...
Sent from my SM-N950W using Tapatalk
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 06-15-2019, 03:24 PM
BScout BScout is offline
Not a bug. A Eucontrol setting. Change the setting and the behaviour will change.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 06-15-2019, 04:31 PM
xrekcor's Avatar
I haven't seen this happen, and don't recall ever seeing that one at least not since 2018.# and didn't see that in PT10 either, but then I didnt use EuControl with PT10.
further to that 2019.5 seems rock solid the only major difference is CPU usage seems a lot higher, and if I have my MBP connected to the internet I get usually get a prompt about removing possible problem plugins (can't remember the error number) in the previous ver the prompt was about increasing Buffer Size (6101). The problem goes when the net is switched off.
if you are able and have the time backup you system and give it a try 20219.5 that is.
Rob
Old 06-15-2019, 05:21 PM
Cryos's Avatar
I may do that . I just have make sure I can revert my iPad back to an earlier version of the pro tools control app.
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 06-15-2019, 05:23 PM
xrekcor's Avatar
backup your iPad too then you can restore from backup
Rob
Old 06-15-2019, 05:24 PM
Cryos's Avatar
Good call .
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Pro Tools Control App-simple, silly question VRW ProControl, Control|24, Command|8 0 12-19-2017 03:49 AM
Faderport & Pro Tools Question, can't control right pan knob... DrFord Pro Tools TDM Systems (Mac) 5 09-16-2017 07:14 AM
Pro Tools Control iPad question SomeOtherGuy Pro Tools 12 0 12-05-2016 11:20 AM
Pro Tools Control for iPad question SomeOtherGuy Pro Tools 12 1 02-27-2016 06:02 AM
A Digital Desk, Machine Control and Pro Tools 6.4 question. Any advice please. Tonetony Post - Surround - Video 0 05-18-2009 09:21 AM
