Old 01-22-2020, 07:10 AM
TNM TNM is offline
Default You get FIVE features to add to PT only.. what are they?
Just curious.. if you were allowed to choose 5 features to make PT the perfect DAW for you or as close to perfect as possible with 5 new features, what would they be? I'll be interested to see what the most popular choices are if the topic gains traction. Limiting it to 5 will also make for quicker posts.
Me, in no particular order:
1) MidiFX plugins, eg step sequencers, arps
2) Integrated drum mode in piano roll
3) Automation Bezier Curves.
4) 64 or more input channels in non HD
5) Integrated Pitch tool OR ARA2, happy with either.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 01-22-2020, 08:15 AM
DontLetMeDrown DontLetMeDrown is offline
Default Re: You get FIVE features to add to PT only.. what are they?
1) Faster launch that doesn’t scan plugins. Only scan plugins when the user chooses to scan them manually in preferences.
2) ARA2 support
3) When batch fading, remove the alert that says “Some clips were outside bounds” (don’t remember it verbatim) and you have to click to adjust- just do it instead of requiring us to confirm.
4) Allow export to more formats like iTunes m4v, flac so we don’t have to use another program to convert.
5) Allow the multiple checkbox feature in the edit and mix view sections. On Windows you still have to do 1 checkbox at a time.
Old 01-22-2020, 09:26 AM
TNM TNM is offline
2) ARA2 support
for the fades just choose "automatically accept bounds" or something in the prefs. If you can't find it let me know and I'll find the exact name for you.
Edit.. I just checked it for you. It's under editing preferences and called Auto accept adjust bounds.
I don't really ever need to do batch cross fades, fades yes, not cross fades.. but I just cut up a bunch of audio on different tracks to test it for you, overlapped the audio at random non snapped AND snapped positions (different each track), used the smart tool to create an X fade area across all of them, hit command F and enter and it did them all at once, no messages. So hopefully I have solved that problem for you...
And if SO, that means you might be able to replace number 3 with another wish. *grin*.
Also, not entirely sure what number 5 is.
If the rumoured new mac/imac/macbook pro performance mode comes out in Catalina which will mirror the windows high performance mode and disable cpu throttling, I have to say that after all this time of planning to switch to windows, that OSX would suddenly be the very best OS to possibly use PT on. From it's window handling to it's proper high DPI support as well as the uber easy one touch way to make any key command for any function without the use of any kind of 3rd party tools, well, it will be unbeatable from my point of view. Apple are obviously listening and I like to think that all the noise I personally created and bombarded the forums with posts and them with emails about, also contributed even 0.01% to them finally taking pro performance seriously :)
I am surprised about the conversion thing.. This is not that common.. maybe reaper does it? Most Daws just handle a few basic formats.. interesting to see it's such a big deal to you. This is why this topic will be fun, to see what makes us all so different.. But I am hoping with ideascale voting closed down, that there will at least be one or two features that have an overwhelming majority vote in here for that I can present to Avid :)
Last edited by TNM; 01-22-2020 at 09:53 AM. Reason: added edit section about fades then performance.
Old 01-22-2020, 09:56 AM
jpsexton's Avatar
jpsexton jpsexton is offline
1) Remove the 32 i/o limit when using 3rd party hardware
2) ARA2 Support
3) Allow upgrades without support subscription
4) Drag and drop plugins with browser
5) Mixed sample rates in project
Intel - Core i7-8700 3.2GHz 6-Core Processor
Asus - Prime Z370-A ATX Motherboard
Asus Thund​erbolt III​ AIC
16GB (2 x 8GB) DDR4-2133 Memory
Patriot - Spark 256GB SSD System Drive
Patriot - Ignite 480GB SSD Work Drive
Hisense 43" 4K Display
Presonus Quantum
OS - Windows 10 Pro
Handle every stressful situation like a dog. If you can't eat it or play with it, Just pee on it and walk away.
Old 01-22-2020, 10:46 AM
moshuajusic moshuajusic is offline
-better designed, more visible MIDI editor smart tool
-playlist soloing follows edit cursor
-MIDI playlists view
-L and ' always move cursor to previous/next clip boundaries. (It's redundant for it to follow tab to transients button. Wouldn't even need a ttt button.)
-"slide" edits with mouse (These are called slip edits in the NLE world, but that causes confusion here.)
-mod key for on-the-fly TCE smart tool trim
Well that's 6. But they're relatively humble.
Oh yeah, multiple open sessions. But at least that's already on their radar.
Old 01-22-2020, 11:22 AM
capt kirk capt kirk is offline
1. PLEASE clip bins, that can be anything, track ,color, sample rate, type, custom, ive got 4000 clips in there sometimes, its easier to go and get the sound AGAIN from soundminer than deal with the clip bin
2....PLLEEEAASSE increase the FONT SIZE in the clip bin....when im forced to use it, its like squinting at hieroglyphics.......even a delineating line between stuff, its so small....
I'll do the consulting FOR FREE!!! just let me help you make it AMAZING...
www.kfaudio.ca
Old 01-22-2020, 11:41 AM
ubxf ubxf is offline
Opening more than 1 project at the same time
Old 01-22-2020, 01:53 PM
foxes's Avatar
foxes foxes is offline
+100000
Beizer curves on midi cc data as well.
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
Old 01-22-2020, 02:05 PM
peterle peterle is offline
1.
build in taker functionality with timecode,subtitles , beeps,count in and progress bar
as overlay on the video stream
should be possible for a video company like avid , even steinberg can
foley artist , soundeditor
Old 01-22-2020, 03:23 PM
JFreak's Avatar
JFreak JFreak is offline
I would be glad with only one -- "scenes". Concept from live consoles as you know; instant recall of complete session settings on a press of a button (or automated).
Janne
Q about the new I/O features Frank Kruse Pro Tools 12 1 04-13-2015 12:23 AM
I need help with the new I/O features lukeyy Pro Tools 9 3 11-25-2010 08:12 AM
Features grebarius Pro Tools M-Powered (Win) 0 05-24-2008 12:02 AM
Are those features in PT7 LE? pietervd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-06-2006 08:52 AM
New features in LE 5.3.1 vonbleak101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 06-20-2002 11:30 AM
