Old 11-16-2019, 06:03 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Dialogue Assembly / Conform
Hello fellow DUCers.
Here's a question that I know has been asked before, but I'm having trouble finding an answer for this specifically.
I'm starting an Indi film, and am going through the AAF they provided. They edited off of some mix track that wasn't even the mix track off of the production sound mixer's files.
Editors exported an EDL and provided all of the production audio to me, but I’m not able to re-link the actual poly files to their edit either through EdiLoad or using the field recorder workflow in PT. Field recorder workflow looks like it's just matching it to many duplicates of the same track.
The poly files from production have lots of metadata and the splits sound so much better than the files they’re using in the AAF, but it’d take years to hand sync based on the naming discrepancies. Is there any way to create a pro tools session with every production audio file, spot to original timecode or something, and then conform those to the AAF? Any other option?
I can provide EDLs, screenshots, or whatever anybody might need to give me a helping hand. I'm not opposed to buying reasonably priced software if it'll for sure get the job done, too.
Thanks in advance!!
-Ryan
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
Old 11-17-2019, 03:03 AM
Pete Gates Pete Gates is offline
Default Re: Dialogue Assembly / Conform
Hey Ryan,
Surprised EdiLoad didn’t work, maybe try Kraken (disclaimer: written by a friend of mine but it is good!) http://krakensoftware.co.uk
Cheers,
Pete
Old 11-17-2019, 04:59 AM
Cheesehead Cheesehead is offline
If that mix track doesn't have the original metadata in it, it will never re-link to anything.
EDL is one way to go, with Kraken as Pete says.
Personally I'd get an edit assist to conform the sound rushes to the picture and re-deliver it to you.
Mac Pro 6,1 12 core, OSX 10.14.6, HD-Native TB, Trinnov MC, 888 IO, 192 IO, Sync HD, AJA IO XT, MC Mix, PT Control, Eucon 19.9, PT 2019.10
Old 11-17-2019, 06:00 AM
ubxf ubxf is offline
you might want to give this a try.
https://www.synchroarts.com/products/titan/overview
Old 11-17-2019, 07:33 AM
It's hard to see from those low res screenshots but to me it looks like you were given a regular CMX EDL which truncates any source names to 8 or 10 characters and 999 events. This leads to wrong results as different material will look the same to the conforming software. Ask the cutting room for a file32 format EDL which won't truncate long names contained in it and try again.
file32 should be the default for any EDL exports nowadays because usually no one incl. cameras stick to 8-character naming anymore.
Unless I am on the wrong path here and those are in fact correct EDLs?
That being said, the field recorder workflow using the AAF should work regardless as the EDL isn't needed. Could be a million reasons. match criteria set wrong, AAF with stripped meta-data (use a non embedded AAF to check) or both. Very hard to diagnose. What are your match criteria settings and can you make more hi-res screenshots? If you get that to work you won't need to mess around with EDLs in the first place which saves a ton of time.
F.
PTHDn 2019.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 11-17-2019, 03:23 PM
LDS LDS is offline
Would it be possible to sync the audio using something waveform based? Like Resolve or PluralEyes?
littledevilstudios.com.au
Pro Tools Ultimate 2019.6. OSX 10.14.6. HDX. Avid Omni. MacBook Pro 2018. 6 Core i7. 32Gb. 4x mSata SSD Drives + 4x HDD. Blackmagic Intensity PCIe. ATI RX580. Sync HD
Old 11-18-2019, 02:06 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Ryan looking at your EDL screen shot (from what I can just make out) it looks like it contains the WAV Sound Roll name in the clip name column. You can use the EdiLoad column transfer window to transfer this info into the Roll Name column. You can also use the EDL cleaning function to reduce the track count before exporting the conform reference tracks. See the video in the following blog post for more info on how to manipulate an EDL in EdiLoad for conforms:
https://www.soundsinsync.com/blog/cu...-using-ediload
I’d also be happy to look at your files if you email them to me or you can send via the support page. Best to send all EDLs and send an XLS file by opening the WAV file list window, drop the parent folder containing all location WAVs onto it and export the XLS file. I’ll be able to use the XLS file to see what metadata is contained with your WAVs.
Regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
HTML code is On
Control 24 fader pcb assembly Davidwilson ProControl, Control|24, Command|8 0 06-17-2019 01:39 AM
Production Assembly?? Naylorfreak Post - Surround - Video 0 04-06-2012 01:04 PM
Anyone still using Loco/Titan? Need to do some re-assembly mondoJML Post - Surround - Video 4 04-21-2008 02:38 PM
auto conform but no Post Conform Richard Fairbanks Post - Surround - Video 5 03-21-2004 11:35 AM
computer assembly question in10shun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-13-2002 04:55 PM
