Old 07-05-2016, 12:20 AM
Matt Darcy Matt Darcy is offline
Default Protools application manager - stops mac shutting down
I have pro-tools application manager on two mac's (always kept up to date).
These two macs, whenever I try to shut them down, they rarely actually complete the shutdown process and just hang until a forceful power off.
A little bit of investigation and it looks like Avid Application Manager doesn't actually shutdown / exit properly very often when it is running and you issue shutdown on your mac. I'd be interested if other people have noted their mac not shutting down properly on a regular basis with application manager installed and running. Could use some feedback before trying to progress this forward.
Thanks.
Old 07-05-2016, 04:16 AM
Kirby B. Kirby B. is offline
Default Re: Protools application manager - stops mac shutting down
Download and install CCleaner and in "Tools" disable it's startup
Old 07-05-2016, 05:28 AM
ClaudeM ClaudeM is offline
You can uninstall Pt App manager. There is an Avid Uninstaller folder in your Applications folder.
Old 07-05-2016, 05:34 AM
tamasdragon tamasdragon is offline
Simple, get rid of it. Really, a good idea but it's not working as it should.
my blog:Tamas Dragon
Old 07-05-2016, 09:32 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Thanks.
Sounds more like the Coreaudio issue.
Help us help you:
What OS, what version of PT??
IMDB
Old 07-07-2016, 01:17 AM
what's the coreaudio issue ? I see lots of threads about how to set up and the like in a search but not specific issue related to shutdown.
I'm running 10.11.5 at the moment annoyingly, as I accidentally upgraded to 10.11.4 and hit the cpu spike problem referenced.
I'm running Protools 12.4.0.294
I'm running application manager 2.5.6.12065
Welcome your input.
thanks,
Old 07-07-2016, 07:36 AM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
I just disable it from starting up on my Mac ..., heres how (click on attachment) ..., Disable Avid APP MANAGER on Startup.jpg
After following this procedure and you restart your Mac , Application Manager will no longer load and open on startup . If you do need to open it you can however still do so from going to your Applications Folder and clicking on it from there (or elsewhere if you created a shortcut for it)
Also better apparently to check for updates directly from your Avid account than depend on the buggy App Manager.
Pro Tools 2019.6 Native * Slate Raven MTi-1 Version 3.3.0 * AVID MBox3 Pro * OSX Mojave 10.14.6 * MAC PRO (late 2013) * 3.5 GHz 6-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D300 2048Mb * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 (Broken !!! - shyte support from Blackmagic Singapore > A-Holes) * Samsung SSD's 850 Pro * WD Black HDD's
12.5.1 not available in Application Manager noeqplease Pro Tools 12 13 06-21-2016 03:30 PM
Application Manager v2.5.1 Now Available DigiTechSupt Technical Alerts 0 01-12-2016 08:02 PM
Application Manager Prentiss Carr Pro Tools 12 4 10-18-2015 09:25 AM
Application Manager 2.4.4 unkJE Pro Tools 12 8 10-14-2015 02:56 PM
OS 9 : Pro Tools STOPS when application switching mu-tron-kid Pro Tools TDM Systems (Mac) 4 11-14-2006 09:38 PM
