Old 10-31-2002, 08:09 PM
clam clam is offline
Default Amplitube settings not saved...
I am running amplitube (not the demo) on XP with Intel P4 system. I have not been able to save the plugin settings for a session. I tried everything I can think of, even reloading the latest download (1.1.1). I seem to remember someone else reporting a similar problem. IK said they would look into it, that was a few weeks ago. This is a cool plugin but I need to be able to save my settings. Is anyone else having ths problem???
Old 11-04-2002, 08:54 AM
IK_Jason IK_Jason is offline
Default Re: Amplitube settings not saved...
Make sure that the the
Amplitube Settings folder
Amplitube.xrs
Amplitube.dpm
Amplitube.dpm.rsr
Amplitube.ike
are in the DAE/Plug Ins folder. If so, cool.
Jason Williams / Technical Support
IK Multimedia U.S. Division
Email: [email protected]
Old 11-04-2002, 01:11 PM
Michael Carpenter Michael Carpenter is offline
I'm having a similar problem. It seems to save my settings for some songs but not others. All the files you mentioned Jason are where they need to be.
I have a theory that if i get a sound and do a 'save as' so that i can use it for other tracks, and then i actually use it and modify it for the other tracks, it changes it for the song i originally set it up in. Don't know if that makes sense or not..
I don't have a lot of faith in it at the moment. There's nothing worse than opening up a session and not knowing if everything is where you left it, so i've been using Amplitube a little sparingly. And when i have been using it, i've just been playing with it straight up, not tweaking presets, saved patches etc..
MC
Old 11-04-2002, 05:34 PM
A temporary solution to this is to tweak your presets to the particular song then save the preset in the directory where your session files are. Then if by chance it doesn't load back up you can tell AT where the presets for that song is and load it up.
This will work until we can find the reason why your system doesn't hold it.
Old 11-08-2002, 12:38 AM
I was able to get the Amplitube plugin settings to correctly save by creating a Amplitube folder in DAE/Plug Ins and putting the files Jason mentions in his earlier reply-
from Jason-
Make sure that
Amplitube.xrs
Amplitube.dpm
Amplitube.dpm.rsr
Amplitube.ike
It appears that they need to be in a DAE/Plug Ins/Amplitube folder. Chris
Plug in saved settings? Jono_G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-25-2010 06:13 PM
amplitube: how to load saved settings pre911mindset Virtual Instruments 0 12-31-2008 06:40 PM
are plug-in settings....... saved?? gitarzan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-12-2003 11:27 AM
USD/VSO settings not saved in 5.1 millerbud Pro Tools TDM Systems (Mac) 1 03-30-2001 06:14 AM
Settings not saved in PT 5.1 Robert U Pro Tools TDM Systems (Mac) 2 03-14-2001 06:52 AM
