Can\'t load saved EQ settings for Digirack 4EQ
For some reason, I can't retrieve any eq settings for the 4 band eq that comes with Pro Tools LE. I click on the bar that says "factory default" to select the desired eq settings from what would normally be my list of saved eq settings and get nothing. None of my other Digirack plugs have this problem as I am able to retrieve saved settings for them with no problem at all.
Anyone else had this problem???? [img]images/icons/confused.gif[/img] Thanks in advance, Mike |
Re: Can\'t load saved EQ settings for Digirack 4EQ
Anyone???
I have no problems recalling plug-in settings for the 4 band DigiRack EQ (mono or multichannel).
I'm not sure why only this plug-in would be acting abnormally on your system, but try trashing your DAE prefs (entire folder) and see if that changes anything: -The DAE prefs folder is located in the C:/ Program files / Digidesign / DAE folder Brent |
No luck. I blew it away but still had the same problem. I had this happen a few months ago as well, but the problem disappeared for a couple of months and now has come back again. No problems with the other plugs, just the 4 band EQ.
Plug in saved settings? | Jono_G | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 06-25-2010 06:13 PM |
amplitube: how to load saved settings | pre911mindset | Virtual Instruments | 0 | 12-31-2008 06:40 PM |
are plug-in settings....... saved?? | gitarzan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-12-2003 11:27 AM |
USD/VSO settings not saved in 5.1 | millerbud | Pro Tools TDM Systems (Mac) | 1 | 03-30-2001 06:14 AM |
Settings not saved in PT 5.1 | Robert U | Pro Tools TDM Systems (Mac) | 2 | 03-14-2001 06:52 AM |
