Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 03-22-2024, 03:15 PM
wickett wickett is offline
Default Carbon Optical input spdif not detected
I am trying to archive a DAT tape using Pro Tools Carbon but I am getting no sound.
I have the DAT machine's digital output connected to the Carbon via an SPDIF coaxial to optical converter.Pro Tools clock is set to external adat reserved 1-28.
In the Pro Tools Hardware Setup>Optical I/O settings>Optical In Format (Detected) adat ports 1 and 2 show N/A.
I have had it workingin the past. I don't know what it's not working now.
Can anyone help please?
Old 03-23-2024, 03:08 PM
Top Jimmy's Avatar
Shooting in the dark here but I believe some DAT machines only spit out clock when they’re actually playing something. Are you setting up everything while signal is coming from the DAT, or is the machine at stop?
Digi gear in the past has been hinky playing nice with some DAT machines. (Panasonic I think but I could be remembering wrong).
Is the sample rate of your PT session the same as what’s coming from the DAT?
James Cadwallader
Old 03-23-2024, 03:29 PM
Default Re: Carbon Optical input spdif not detected
Indeed. Do you know the sample rate/bit depth of the DAT tape (get the player to display that if possible). And is that set correct. Don't assume it has to be 48kHz. For example a 32 kHz DAT is not going to be readable on a Carbon since it does not support 32kHz S/PDIF.
Getting No Signal From The SPDIF Input On My 003 (Optical). epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-10-2010 11:12 AM
adat optical input and spdif at the same?-001 16yearsjeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-20-2003 07:52 AM
whats the difference between adat optical and spdif optical? Vegadark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 04-07-2002 07:42 PM
how to set optical input to spdif? HELP! jason levy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-15-2002 07:45 PM
spdif sync+optical input emreramazanoglu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-01-2002 05:32 AM
