Old 03-19-2024, 01:00 PM
Frans29 Frans29 is offline
Default HD driver 2024.3 not working properly with Ventura 13.6.3?
Updated to Pro Tools 2024.3 and also updated to HD driver 2024.3.
Pro Tools works fine, but HD Native Thunderbolt is not present anymore as ASIO device in Mac OS.
Downgraded only the HD driver to 2023.3 and Mac OS can use HD native thunderbolt again as audio device.
Pro Tools still seems to work fine with this mismatch in versions as far as I can tell up till now.
Old 03-19-2024, 01:56 PM
Default Re: HD driver 2024.3 not working properly with Ventura 13.6.3?
You mean CoreAudio? ASIO is for Windows, the dark side of the force.
Old 03-19-2024, 02:03 PM
gives's Avatar
gives gives is offline
No issues here. It was just a minor update, so it should not have messed anything up.
Been mixing a series for several days and nothing to report. As solid as it was and grateful for that! G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 03-20-2024, 02:07 AM
Ah yes, indeed CoreAudio I meant, sorry for that.
Old 03-20-2024, 02:08 AM
Hmmm interesting, I see you’re on 13.6.5. Maybe the problem is the fact I’m on 13.6.3
Old 03-21-2024, 11:00 AM
gives's Avatar
Not sure. But all of the last 3 updates are security related only as far as what Apple says about it.
I have had no issues since I went up to Ventura for months or since I upgraded to my New Mac Studio form a 10 yr old Mac Pro Trash Can.
I always repair the internal drive with Disk Utility before or after, which seems to keep things solid here. One friend I had do that said it fixed his issues he was having. You just have to launch into the internet recovery mode. If you are on an Apple Silicon Mac, then you just start the Mac by holding the power button for about 8-10 seconds and then I will launch correctly to repair using Disk Utility. Maybe that will help your thing. Repair all the partitions starting at the bottom to the top. Note to start at the very bottom of the tree. My image was not quite at the bottom.
G
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 GRT Pro Tools Scripting SDK Toolkit 6 03-19-2024 01:11 PM
mac OS Ventura driver for yamaha 01v96i OARecords General Discussion 13 02-10-2024 11:00 AM
Can’t install Thunderbolt Driver for DADMan on Mac Ventura. TheoNogueira Pro Tools | MTRX & MTRX Studio 7 11-27-2023 01:50 PM
Screen sharing (VNC) on Ventura 13.6 working? Frank Kruse macOS 2 10-09-2023 12:54 AM
S3 I/O Not working with Ventura Dj-Ike Avid S1, S3, Dock and Control App 5 01-31-2023 11:06 PM
