Old 03-08-2024, 06:51 PM
efunc efunc is offline
Default Can't import PT5.1 Sessions or SD2 files
Hi all, I have a 30 year old project I need to convert and deliver (tomorrow!).
It started life on my PT 5.1.3 TDM rig in MacOS 9.1 on PPC 9600. The audio files are all 16bit 48khz SDII.
In order to convert this I've installed OSX 10.8.5 and PT 10.3.10 on a MBP 2012 Retina.
I've copied all the data onto a USB thumb drive and then onto the boot drive attached to the Macbook.
The problem is after doing all this I find that PT can't import the sessions. They are greyed out and can't be selected using Import session data. Even the audio files are greyed out so can't even be imported as audio. What did I do wrong? Is this about MacOS 9 resource forks and data forks? Or should Pro Tools 10 be able to make sense of it?
If anyone knows I'd be very grateful. Thanks
Old 03-08-2024, 10:12 PM
Top Jimmy's Avatar
Default Re: Can't import PT5.1 Sessions or SD2 files
Most likely yes. If the session was archived on an HFS+ drive and you copied it to a FAT32 thumb drive then you absolutely stripped the resource forks.
James Cadwallader
Old 03-09-2024, 04:46 AM
Doh! Schoolboy error
Thanks very much for the tip. I've lost valuable time, but thanks for setting me back onto the right trajectory.
Import Sessions Data doesn't copy audio files s.d. finley Pro Tools 4 07-11-2022 08:38 PM
Pro Tools 12.6 not copying audio files on import! = Lost files DJ Hellfire Avid Pro Mixing General Discussion 2 10-07-2016 07:27 PM
Import track or session files ? And Import, then SAVE ? theivories Pro Tools 11 1 09-25-2015 07:36 PM
All Sessions using SDII files are missing all audio files and won't relink bigmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-18-2009 12:54 PM
Unable to import REX or Acid files as group files in 7.4 Luigi Lazareno Pro Tools TDM Systems (Mac) 2 03-11-2009 08:07 PM
