Old 02-03-2024, 02:14 AM
lucapane02 lucapane02 is offline
Default Pro Tools 2023.9 slow when editing playlist
i have a problem with my pro tools 2023.9 with macOS Ventura.
When i edit audio (crossfades, trims, zoom view etc.) with playlist pro tools is really slow (i see many times crown wheel). Also the playback stops between two different playlist comp in the main view with DAE error disk too slow.
This happens only when i work with playlist comp.
Old 02-03-2024, 08:39 AM
Default Re: Pro Tools 2023.9 slow when editing playlist
How many playlists? I can confirm this has been an issue with 2023.9 (at least - probably going back a long ways) on Ventura and Monterey on multiple very fast machines (Mac Studio Max and Ultra, HDX and Native). I frequently need to work with tracks which contain hundreds of playlists (200 - 400, all sort bits) - and sometimes need to work in Playlist view (in order to vew multiple options). As the number of playlists goes up, everything is fine and snappy until you enter playlist view - then the systems slow to a crawl; real workflow killer... I haven't had the time to file a bug report, but we all probably should.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-03-2024, 09:02 AM
in this case 9 tracks with 12 playlist each... Did you try with 2023.12? Same problem?
PT 2023.12 quits on editing memory location. Tiyan Pro Tools 5 02-29-2024 05:18 AM
Playlist editing problem with S6 Stereo Missile Avid S4/S6 6 11-28-2015 04:57 AM
Playlist Editing...Pretty Please ..:) lemix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-09-2005 11:41 AM
Retaining Selection in PlayList Editing sydphi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-09-2003 08:21 PM
