Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 01-20-2024, 01:53 PM
itsjustmeee123 itsjustmeee123 is offline
Default Suggestions for a portable interface.
I just got a new M2 MacBook Air that I’d like to use to record an occasional guitar or vocal track. I wouldn’t be traveling with it and I’d be using it sparingly so I don’t need anything over the top. I would like for it to have a USB C connection and I love the option of mixing the direct signal with the playback. I’d be recording to a stereo track and the only plugins I’d be using is something like Guitar Rig 7 or a compressor and EQ.
My question is will latency be much of an issue with this type of scenario and is a blend direct/DAW knob really necessary? And what interface would everyone recommend. I’d like to keep the price around $150.
Thanks in advance for any advice.
Old 01-21-2024, 12:16 PM
Bill0287 Bill0287 is offline
Default Re: Suggestions for a portable interface.
This is basically what I do (more or less). Take a look at Presonus Audiobox USB 96 devices. I don't know about Mac compatibility, so check on that. I only want to hear the processed signal, so I am turned up all the way on the mix.
Pro Tools Artist | Dell XPS 8960 | Windows 11 Home 64-bit (23H2), Intel 13th Gen i7-13700 | NVidia GeForce RTX 4060 Ti 8GB Graphics | 32GB RAM | 1TB SSD system drive | 7200 RPM internal recording drive (2TB)
Old 01-21-2024, 12:57 PM
its2loud its2loud is offline
Audient Evo 4
https://evo.audio/products/audio-int...vo-4/overview/
Old 01-21-2024, 03:17 PM
[QUOTE=itsjustmeee123;2692266]I just got a new M2 MacBook Air that I’d like to use to record an occasional guitar or vocal track. I wouldn’t be traveling with it and I’d be using it sparingly so I don’t need anything over the top. I would like for it to have a USB C connection and I love the option of mixing the direct signal with the playback.
Uh probably no... Assuming you are producing some standard vocal/electric guitar recording you likely should be recording to *mono* tracks, you will mix to stereo but why would you record to stereo? Are you singing into a pair of stereo mics? Trying to record to stereo is only likely to create a mess for you/not be as efficient/flexible as recording to mono and mixing to stereo. Start by finding some introductory tutorials on recording vocals and electric guitar (using amp sim software) with Pro Tools, on YouTube or Groove3 (paid videos and very good).
...and the only plugins I’d be using is something like Guitar Rig 7 or a compressor and EQ.
It depends on what you are doing with Guitar Rig 7, but if it's a usual distorted/crunch/rock/metal electric guitar you'll need to monitor though the plugin, and the hardware monitoring in the interface likely won't help you with electric guitar, you'll likely disable it while tracking guitar. And you'll want to run at small HW buffer sizes to reduce latency.
It may be useful to hardware monitor while singing but depends on how sensitive you are to latency. And if you are tying to say track electric guitar and sing at the same time you may have problems configuring a mix of hardware and software monitoring without a slightly more complex interface that includes per-input/output control of the hardware mixer in the interface.
Software monitoring latency is largely dominated by the H/W buffer size. If software monitoring the dominant factor is what H/W buffer size can you get the DAW to run at reliably without crashing. The lower-end/cost interfaces won't have record setting latency specs, they typically use USB-Audio Class compliant drivers on Mac and so are not heavily optimized for latency but you might well never need this fancy performance. They also don't have the more advanced hardware mixer capabilities. If you want a lowest latency USB interface the RME BabyFace Pro FX is about as good as it gets in a compact interface, but it's $1k. At the $150 price point you can basically look around and pick an interface from any decent vendor (in no specific order: Focusrite, Presonus, RME, UAD, Motu, Audient) they'll be largely the same, and spend time using it learning how stuff works.
Old 01-22-2024, 11:07 AM
[QUOTE=Darryl Ramm;2692328]
Thanks Darryl. I meant that I'd only be using a stereo backing track to add some additional vocals and/or guitar with as opposed to a full on session with multiple tracks.
I ended up going with the Audient iD4 MKII. It checked all of the right boxes for what I needed.
Old 01-22-2024, 04:23 PM
[QUOTE=itsjustmeee123;2692413]
Great stuff, just use the heck out of that Audient and it may last you a long long time, and you'll know all you need to make the next decision if you ever want/need to upgrade.
Need I/O suggestions for a PT 10 portable rig Ed Douglas macOS 4 06-28-2012 11:40 PM
Portable on the go Pro Tools suggestions wreckthisplace General Discussion 3 04-19-2010 03:15 PM
Portable Digital Recorder Suggestions please! SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-12-2005 10:21 AM
OT: Any suggestions on portable MD? pindebraende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-05-2002 10:47 AM
OT: Any suggestions on portable MD??? pindebraende General Discussion 10 09-03-2002 09:16 AM
