Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-23-2023, 06:16 AM
musicube musicube is offline
Default Midi latency with dante setup
Hi there,
I'm using PT on my Laptop connected to a Focusrite RED NET 5 Interface via Dante. With that configuration I experience a tremendous latency working with Midi even when sample buffer size is set to 64 samples. If I use the same session with my MacBook speaker output, latency is normal and fine.
My question: Does anybody experience similar phenomenons with Dante or RED NET 5? I would like to locate the problem without buying another interface/connection and finding out that the problem is located somewhere else.
Thanks in advance
Matthias
Old 11-23-2023, 11:57 AM
TJ Allen TJ Allen is online now
Default Re: Midi latency with dante setup
Hi Matthias,
Are you using the Dante Virtual Soundcard to connect your laptop to the Rednet interface?
If so, Dante Virtual Soundcard has a relatively high latency, compared to connecting directly to a dedicated device. What kind of latency figures are you seeing in ms?
Tim
Dante latency with MTRX PT_NOOB_CH Pro Tools | MTRX & MTRX Studio 6 05-22-2023 05:16 PM
Dante DVS & 3rd party USB interface setup citysoundman Pro Tools 8 04-19-2023 11:54 AM
no audio past channel 32 in a 64x64 Dante setup? naughty G Third Party Interfaces 7 08-04-2020 01:06 PM
MTRX Dante latency stuck at 1ms LukeHoward Pro Tools | MTRX & MTRX Studio 1 02-19-2018 11:13 PM
MIDI setup on Mbox - my sequencer - latency? LukeDog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-09-2003 12:00 AM
