Old 10-03-2023, 11:43 PM
lonestarparis lonestarparis is offline
Default STRIKE doesn't run anymore
Hi forum,
You don't see me posting often, because my IMAC late 2013, OS 10.8.5 and ProTools 10.3.7 have been running smoothly.
But at the moment STRIKE (update 1,5) will not run anymore. I hope you can help me get it back on track.
I get these error messages:
"Error #-192 Unknown error"
"Protools could not load the following plugins, either no valid authorisation could be found, the ILOK key was not connected, or plugin was damaged"
After re-installing STRIKE 1.0 (both cd's) and starting ProTools again, I get "The following plugins were made inactive, because they could not be found in the plugin folder STRIKE (1)"
My question: should I de-install my STRIKE plugin and re-install it?
Best regard
C
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Novation 25 sl mk 2 controller
Focusrite Platinum Voicemaster pro
AKG 451 C matched pair
AKG 414 C XLS matched pair
Sennheiser 406 T matched pair
Mackie HR824 mk2
lots of fine guitars
homestudio, retired guitar teacher, enjoying life and recording
Old 10-03-2023, 11:56 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: STRIKE doesn't run anymore
First reinstall the plugin and try again.
It says you have authorization issue. Check the compatibility of your iLok license manager, in case you have mistakenly updated it to incompatible (to your old system) version you may need to ask iLok for an older installer.
Janne
Old 10-04-2023, 07:50 AM
Thank you for your reply.
I did re-install STRIKE 1.0 and 1.5. But when I want to start it I get the error
that it is "not in the plugins folder".
How can I place STRIKE in the "plugins folder"? I can't find this folder. What is it's location?
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
Old 10-04-2023, 08:04 AM
JFreak's Avatar
RTAS: /Library/Application Support/DigiDesign/Audio/Plug-Ins
AAX: /Library/Application Support/Avid/Audio/Plug-Ins
Janne
Old 10-04-2023, 11:46 AM
I'm afraid I'm as good with computersoftware as I am with my car's engine: not good at all.
I tried practicly the entire afternoon and big part of the evening, deleting STRIKE, re-installing, unable to find how to get STRIKE on the right location.
Very frustrating..
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
Old 10-04-2023, 11:57 AM
JFreak's Avatar
Janne
Old 10-04-2023, 12:13 PM
Southsidemusic's Avatar
And you haven’t updated anything like OS or anything?
I thought we needed to have the 2.0 version for 10.3.5 and up but it was a long time ago and i am sure I am wrong there.
I think we had Version 2.0 for PT10.3.8 HD and then PT 12.X and version 3 so if you have not dome anything, do a Preferences delete and then let the computer re-find asll the plugins and see if that helps.
And the ilok key is the first Gen green ”key” shape right? All the other licenses works that is on that ilok key?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-04-2023, 01:03 PM
You're right: I have one old green iLok key and one 'modern' smaller one. All other licences work fine.
I downloaded the four STRIKE 1.5 cd's on an USB stick and every time I re-install it it says OK.
(My PT isn't HD, by the way).
And my STRIKE is version 1.5. Rather old, but for my recordings just fine.
I'll try a Preferences delete, as you suggest.
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
Old 10-04-2023, 01:39 PM
JFreak's Avatar
Strike 1.5 was released on March 6th, 2009.
Janne
Old 10-05-2023, 12:29 AM
Hi jFreak,
On my iLok key STRIKE 1.5 is active. Does this mean that it is authorized, as far as iLok is concerned?
On the same key I see that my original STRIKE 1.0 is inactive. And I can't change that to active.
I also opened Preferences: there I see STRIKE 1.5, as if all is normal. Should I trash all what's in it and hope for the best? Or should I only delete STRIKE 1.5?
Starting a recording I get this error: "Protools could not load the following plug-ins, because no valid authorization could be found, the iLok key was not connected or the plug-in was damaged: STRIKE.dpm"
So you were right: it is an authorization issue.
Both my iLok keys seem OK. And all other plug-ins work perfect.
I hope this info is helpful?
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
My Phoenix II doesn't work anymore mnstudio Pro Tools 1 01-03-2022 02:00 AM
MBox 3 Pro doesn't read anymore tdames FireWire & USB Audio Interfaces (Win) 1 04-20-2015 11:20 AM
itunes doesn't work anymore?!?! ichbin Pro Tools TDM Systems (Mac) 5 01-09-2006 05:38 PM
Midi doesn't work anymore kd_rome MIDI 1 06-24-2004 10:16 AM
Doesn't anybody use Masterlist CD anymore?? Nine Spine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 11-21-2002 11:20 AM
