Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 12-14-2022, 03:39 PM
MarkGenero MarkGenero is offline
Default Recording Roland Juno ds88 sounds directly into pro tools via usb cable?
So I would like to know if anyone has been able to record the audio from a Roland Juno Ds88 (or ds76 or ds66) directly into pro tools by usb cable from the keyboard to computer? I know you can record midi this way but would like to know if I can bypass the audio digital/analog conversions that happen when you use the preamps on the audio interface. Unfortunately there are no light pipe or other digital interfaces on the keyboard or my focusrite scarlet interface. USB is what I got. The Roland website see you can do this but they only list other daws like Cubase and not pro tools.
Old 12-14-2022, 11:13 PM
smurfyou smurfyou is offline
Default Re: Recording Roland Juno ds88 sounds directly into pro tools via usb cable?
Pro Tools will only see the inputs of the selected Playback Engine.
~Will
Old 12-15-2022, 12:33 AM
You can go line/preamp in to your interface, I doubt that will make any real difference and this is what I'd do and is simple/easy.
I doubt any of the synth audio is world shatteringly great, and you can get better with good VIs. So have fun playing around, but treat stuff as analog scratch tracks, record the MIDI and play with VIs.
You can record audio to a USB stick.
You can connect the DS88 via USB and use it as the playback engine - if you are are using a Windows PC you really want Roland to provide an ASIO device driver for it. You need to look at what they provide. I am a non-Fan of Roland's ability to develop and support drivers.
If you are on a Mac you can try using aggregate I/O to add the USB keyboard device to your Scarlett USB interface. Aggregate devices are frequently flakey PITA, and how well this works depends on the quality of the vendor's drivers. And I suspect this keyboard is using class compliance (ie. Roland is not providing drivers) or given it is Roland I would be cautions of their drivers. In general Roland is an interface manufacturer I'd avoid.
I would probably just make it easy and go analog in, and record MIDI. Play with VIs and/or learn enough to work out what your next hardware step-up is.
Old 12-29-2023, 01:44 AM
Kaianglow Kaianglow is offline
I was only able to do this after installing the correct drivers for the Juno DS.
How to bounce MIDI to Audio if Instrument sounds are on external DAW (Roland Juno-Ds) mmmtastybusch MIDI 0 12-21-2016 09:28 PM
Pro Tools and the Roland Juno-G mrvona Pro Tools 11 12 09-03-2014 05:30 AM
Roland Juno 60 Vintage Analog Synth - Juno-60 FREE SHIPPING nexis Buy & Sell 4 03-28-2013 02:02 AM
Roland JUNO Gi and Pro Tools SE. Laurenz Roth Pro Tools SE and Essential (Win) 2 04-05-2012 03:17 AM
Roland Juno-G with Pro Tools midiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-17-2007 05:57 PM
