Old 11-05-2021, 04:59 AM
JJRivers JJRivers is offline
Default M1 Max MacBook Pro Monterey, Kontakt Crashing Pro Tools
Hi guys, just wanted to know if anyone else is struggling with Kontakt on Pro Tools 2021.10 (latest version). Ive gone through moving plugins from used to the unused folder.
The Kontakt 5 plugin gets stuck in black Gui as in the attached photo when opening a session. When I move it to the unused folder, the session will load no problem.
Ive gone through uninstalling all NI apps and reinstalled Kontakt 5 but getting the same issue. Ive also trashed PT and NI presences with no luck. The Macbook is running my time machined imported back up and Im not sure whether its worth deleting everything on the HD and installing all plugins trying from scratch but having reinstalled Kontakt 5 via Native Access I don't think it would make a difference but maybe worth a shot?
System: MacBook Pro 14" M1 Max running Mac Osx Monterey (I understand its not supported right now by NI but just thought Id post to see if others are having the same issue).
Old 11-05-2021, 05:03 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: M1 Max MacBook Pro Monterey, Kontakt Crashing Pro Tools
Sorry to tell you but you need Kontakt 6
Janne
Old 11-05-2021, 05:39 AM
I have both Kontakt 5 and 6.
I just tried Kontakt 6 on its own inside of a new Pro Tools session and it gets stuck on the same part while loading the sample instrument.
Old 11-05-2021, 06:10 AM
JFreak's Avatar
I can assure you I have PT 2021.10 running on Monterey M1 mac mini, and Kontakt 6.6.1 loads all my libraries as it should.
Janne
Old 11-05-2021, 09:07 AM
@JFreak good to hear that! Im trying to figure what is up with it ... could it be some other plugin affecting it, any recommendations?
Old 11-05-2021, 09:22 AM
JFreak's Avatar
Could be. For troubleshooting, move all plugins except Kontakt to the unused folder and try again.
Janne
Old 11-08-2021, 01:29 AM
Ive moved all the plugins to the unused folder except for Kontakt but still no luck.
Ive created a new Pro Tools Session - I select Konakt and the plugin loads, but when I select one of the Kontakt sample instruments from the side menu it gets stuck and freezes Pro Tools (force quit is the only option).
Old 11-08-2021, 01:33 AM
JFreak's Avatar
That is strange. Are you sure you have updated to latest Kontakt (6.6.1) and also checked that your libraries are updated? In here it seems to work nicely.
Janne
Old 11-08-2021, 05:21 AM
Hi @JFreak appreciate the reply.
Ive just checked I have the latest Native Access, and it shows all available products are up to date.
Ive tested Kontakt 5 and Kontakt 6 outside of Pro Tools and they are playing the sample libraries fine. They also work fine inside of Logic Pro X.
Is it worth a shot maybe making a new user account in my Mac and testing Pro Tools with Kontakt in there? Cheers!
Old 11-08-2021, 11:00 AM
fredepanduro fredepanduro is offline
I'm having the same issues with Kontakt and similar issues with SampleTank 4.
It seems like it's when Pro Tools VI's are trying to load samples in to the plugin it just crashes with spinning/frozen beachball. Both works perfect in standalone mode.
I'm in contact with IK Multimedia support, but they solved it yet.
Hope for a quick fix soon
I'm on a new MacBook Pro 2021 16" M1 Pro , 16GB Ram, 1 TB SSD.
Mac OS Monterey 12.0.1, Pro Tools 2021.10
Mac Mini 2018 - 3,2GHz I7 6-core, 32gb RAM,512gb SSD
OS X 10.14.4
Pro Tools Ultimate 2019.6
EuControl 2019.7
Apollo 8
UAD Satellite Quad + Eight Core
Avid S3 + Dock
Has anyone tried Pro Tools 2021.7 on the Monterey Betas? off the wall macOS 28 11-17-2021 10:21 AM
Kontakt 5.6.6 crashing PT 12.8.0 noiseboyuk AAX Plug-ins 2 09-07-2017 12:28 PM
Kontakt crashing PT HD 12.4 - help? jonathan jetter Pro Tools 12 1 12-30-2015 02:26 PM
PT 10.3.3 crashing with Kontakt 5 in OSX 10.8.2 Sandborg macOS 3 01-16-2013 02:22 PM
XPAND! Crashing Pro Tools LE 7.3.1 On My Macbook! HELP! UrbanJoe Virtual Instruments 0 01-23-2008 04:14 PM
