Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-12-2020, 02:37 PM
ReynaldoPena ReynaldoPena is offline
Default Using Pro Tools w/ Xbox One X
Hello Team Avid,
I'm using Pro Tools with an Apollo Twin Mk2 quad core audio interface, and a Shure SM7B. I want to be able to use my Shure SM7B for both XBOX One streaming and XBOX PARTY CHAT. I have no issues using it on my streams, however, I don't know how to channel my Apollo's inputs (in this case, the Shure SM7B) to where the XBOX controller can understand the Apollo's microphone signal or language (for lack of a better word).
I was told to use a dual TRS going into line outputs 3 and line 4 on the Apollo, assign Mics to those outputs in Pro Tools and connect the other end of that dual TRS to an audio Y splitter (mic & headphones) for the xbox controller. I tried this and I still get nothing. Any help would be greatly appreciated, thanks.
EDIT: Not sure if its ok for me to do this but here are a few examples of people who've done it. The difference between me and them is the audio interface and maybe the DAW.
-_(*_*)_-
https://www.youtube.com/watch?v=JCg4-r7WL2Y
https://www.youtube.com/watch?v=zYTpNzTaK5A&t=85s
https://www.youtube.com/watch?v=pQpdKAYr9rA
https://www.youtube.com/watch?v=GQ-n5W6DKbs
https://www.youtube.com/watch?v=TvZDjdCcZwU
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-12-2020, 02:44 PM
Default Re: Using Pro Tools w/ Xbox One X
Not clear here... are you trying to record these streams or chats from Pro Tools and record the mic input at the same time?
If not then just set this up in the Apollo Console... that can be all stand alone, you don't need Pro Tools or even the computer running.
Old 11-12-2020, 02:53 PM
Hey Darryl thanks for the prompt response. How are you? Hope all is well. I'm lost in the wiring. The mic is XLR, the line outputs on the Apollo are TRS, the guitar amp is also TRS, the headphone mix, the monitor outputs--everything. if TRS to TRRS into the xbox controller does not work, I was told to use the audio y splitter. Then that also did not work. Then I was told to use Pro Tools or the Apollo's "Console" software to route the mic input into the line output, despite all these adjustments, is like the xbox controller does not recognize the signal from the Apollo. Believe it or not this is the ONLY thing that worked https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
but that would mean I won't be able to use the Shure mic to interact with my audience while streaming (unless I stream straight from the xbox, which does not have multi stream capabilities.
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
16GB ram
Shure SM7B Mic
Pro Tools | Carbon
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-12-2020, 02:54 PM
Whoa. Again just what are you trying to do? Can you answer my previous question.
Old 11-12-2020, 02:58 PM
I am not trying to record these streams or chats from pro tools and record the mic input at the same time.
I'm looking to use the SHURE SM7B going into the Apollo and send it to my XBOX controller via its 3.5m jack. However, I am lost in the wiring (Inputs/output/¿sends?) of it all.
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
16GB ram
Shure SM7B Mic
Pro Tools | Carbon
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-12-2020, 03:19 PM
Forgetting Pro Tools for now.
The Sure Mic goes in mono balanced into the XLR input on the Apollo. You confirm it works in the console, meters move, you can monitor in a headphone etc. Pro Tools is not used/running.
What I'd do is... just handle this sigal as mono in the Console and feed out that mono to one of the line level outputs...
And all the actual plug wiring involved is standard/can be found online. Like https://components101.com/connectors/35mm-audio-jack
So now you have a mono signal on a balanced 1/4" phono socket output from the Apollo.
I'm not sure what else you have running off the TTRS plug in the XBox in terms of speakers etc. I am guessing you don't want to feed them back though the same headphones or speakers connected to the Apollo. The easy way I'd do this is make up my own cable, get a cable with a suitable TTRS plug on one end and wire the mic +signal and ground from the Apollo to the mic input, leave the -ve signal disconnected. Since the XBox is expecting a mic level input you are going to have to turn the level way down on the console. If you are using a gaming headphone off that same socket you could make up a box that had sockers for a 1/4" phone balanced cable and gaming headphones and a 1/8" TTRS fly lead to the Xbox. Or if you are brave just cut the TTRS plug off the headphone and hard wire in a cable to the 1/4" TRS phono plug.
Or start by using an of the shelf splitter for the TTRS input to do some of this... like https://www.amazon.com/StarTech-com-.../dp/B00CPEZ4J6. Plug your current headset in there and then you just need a cable that goes 1/4" phone plug to 1/8" phone plug, TR or TRS cable for that connection back to the Apollo should not matter.
Any of the above *might* introduce grounding/hum issues, and the exact best wiring options between the balanced and unbalanced signals might need some playing with (leaving -ve output floating, how ground vs shield is used etc.), or and you may be better with a balun for the mic. But try it as simple as possible first and see.
Old 11-12-2020, 04:33 PM
Top Jimmy's Avatar
I set up someone using one of these to get a split from his preamp into the mic in on his MacBook.
https://www.ikmultimedia.com/products/irig2/
James Cadwallader
Old 11-13-2020, 09:02 AM
Hi Jimmy, good afternoon. Thanks, I just ordered this. I had to go ahead and cancel because I mind as well get the iRig HD 2. This will allow me to produce music in my phone and hopefully use my Shure mic on the XBOX. Since it only takes in TRS, I ordered this, https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Not sure if it will function with the Apollo and the iRig at the same time though.
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
16GB ram
Shure SM7B Mic
Pro Tools | Carbon
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-13-2020, 09:04 AM
Hey Darryl, as I was looking into these, I decided to call up StarTech.com. They make the 4 position microphone and headphone jack you posted. What they said was that the problem with XLRs is that they require power. 3.5mm's don't carry any power. I went ahead and ordered the irig hd 2, I'll keep you all posted.
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
16GB ram
Shure SM7B Mic
Pro Tools | Carbon
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-13-2020, 10:28 AM
No this is wrong, and you and the Startech rep are unfortunately both confused. I described to you how to make up a simple cable in principle and pointed you at all the wiring info you needed.
XLRs do not "require power". They can be used to carry phantom power, typically for condenser mics, but 1. you are not using a condenser mic and 2. even if you are the questions you asked was about routing from the Apollo to the Xbox so your XLR connection to the mic is coming from your Apollo interface and you would just turn on phantom power there. Phantom power is not provided at the line output and has nothing to do with the connections you are asking about.
Did you change what you wanted to do? Do you now want to unplug the mic each time and switch between the Apollo and the Xbox? If you are talking about XLRs?
The use of an iRig type instrument preamp here between the Apollo output and the mic input of the Xbox is likely unneeded and likely worse than just using a piece of cable. You already have way better preamps in the Apollo that are driving a hot input into the mic the last thing you need is another preamp of any type in the circuit, so you turn down the gain as far as it can go on the iRig and hope that is enough. But all you needed to start with a basic cable wired correctly. I doubt the iRig provides say a transformer coupled input and since its designed for a guitar input its certainly not providing a transformer coupled balanced to unbalanced conversion... so really no point to use over a piece of wire.
Please pick up a book on basic audio engineering, this is really stuff you should not be confused about. A good book is: https://www.amazon.com/Recording-Eng.../dp/159863867X
FS: Pro Tools HD 8 + Pro Tools HD 9 + Pro Tools 9 Bundle iLOK license Delta Music Belgium Buy & Sell 1 02-27-2019 03:33 PM
xBox as sound modules?? CraigLearmont Pro Tools TDM Systems (Win) 0 01-12-2004 10:01 AM
Unbelievably OT: PS2 vs. Xbox vs. whatever dans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 05-16-2003 05:59 AM
