Old 12-20-2019, 04:15 AM
Default 19.12.1.23 window follow oddity
Hi Eddie,
when having a pan window open and I click on a send in PT to open the fader, it will just open for a short moment and then both the pan and the send will close leaving you with neither open.
I guess it's the "close on exit" feature kicking in and closing everything ignoring that I actually wanted to open the send on the other track.
When you do this the other way around (having the send open first and then opening a PAN window on the other track with the mouse) the send will stay open (as it should).
Also sometimes what described first doesn't happen but the send will display for a short moment then close and the PAN window will re-open closing the send.
Overall very confusing when working and not really logical. So I assume it's broken, actually more broken than before.
Oh, and sends still don't seem to follow track selections. When set to auto-close the PAN, Plugins etc. follow fine but a given send will just close when you move the cursor the next track with P for example.
Frank.
Old 12-20-2019, 04:57 PM
bewk's Avatar
bewk bewk is offline
Default Re: 19.12.1.23 window follow oddity
I'm seeing the same behavior as well. It looks like there may have been an update in 2019.12 addressing it but I'm yet to install it to find out. In the release notes it says:
"Control Surfaces
Clicking a track name in Pro Tools will once again attentions track to surfaces when the 'Attention Most Recently Clicked DAW Area' preference is set (PT-256012)"
YMMV
-Chris
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA
• PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD)
• Avid Dock, iPad 7th gen & EuCon 2023.11
• DADman/Eucon monitoring
• BSS (DAN + 100), QSC DCA 1644, JBL 7 Series
• MTRX Studio // 7.1.4
www.quesound.com
Old 12-21-2019, 12:56 AM
I tried this on PT19.12. It is broken. It only took me 1 minute to encounter this. Makes me wonder...
Such an essential function not working is so frustrating and it has been for some time
now. Every new release it’s broken in a different way. :-(
Old 12-21-2019, 08:22 AM
bewk's Avatar
Worth a shot I guess. I'm still hopeful that the new Control app will expand with improvements at a quicker pace now that it's actually out but it is a distraction when something's off like this. I'm tempted to mix with my screen off.
-Chris
www.quesound.com
Memory Location window should follow playback climber Pro Tools 2018 8 02-10-2018 03:44 PM
Plugin window follow select? jasenj1 ICON & C|24 2 10-08-2014 07:39 AM
mix window does not follow c24 send selection Serge Perron ICON & C|24 0 10-19-2010 06:37 PM
edit window doesnt follow timeline ? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-14-2009 06:42 PM
Edit window follow the cursor? D.Orlando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-17-2007 02:55 PM
