Old 09-22-2017, 01:30 PM
ramonetl ramonetl is offline
Default Mac High Sierra release date Monday 9/25/2017
Just saw this announcement. Over all pleased with Sierra. Wonder if anyone has been running any beta versions of this? Definitely do a time machine backup first! Some of the features look interesting. Peter
Old 09-23-2017, 03:06 PM
TheNeil's Avatar
TheNeil TheNeil is offline
Default Re: Mac High Sierra release date Monday, 9\25\17.
Sounds like it's going to be a big improvement, but I expect some big bugs at first.
That and an entirely new file system sounds like a great way to cause issues with Pro Tools.
I definitely want to give this one time for both macOS and PT patches before trying it!
It has had some positive findings from people on here though:
http://duc.avid.com/showthread.php?t=392136
Pro Tools 2018.1 (Non-HD) | macOS High Sierra | 2.6 GHz Intel Core i7 | 8GB RAM | 7200rpm SATA Drive | iLok Cloud | Line6 POD UX2 | 256 Sample Buffer | 1 GB Cache
Old 09-23-2017, 03:20 PM
And what features look intersting? I can't see any reason Pro Tools users should be rushing to upgrade to High Sierra.
Time machine? Anybody risking being at the bleeding edge of OS X releases and relying on Time Machine deserve all the downtime they get.
And nobody should be trying stuff out by upgrading a running system. If you want to be at the bleeding edge, do a clean install on a spare drive or partition and leave your current system boot image alone and a reboot to recover away.
And bootable image backups made just in case with Carbon Copy Cloner or similar.
Ironically eventually High Sierra APFS should help provide a real base for a robust version of time machine. Eventually, once APFS gets stabilized and supported across non-FLASH storage, etc. I'd be hesitant to run on APFS without a great reason.
Old 09-23-2017, 05:04 PM
latweek latweek is offline
And a reminder to download the Sierra installer, in case anyone wishes to roll back.
Old 09-23-2017, 07:21 PM
DetroitT's Avatar
DetroitT DetroitT is offline
"I can't see any reason Pro Tools users should be rushing to upgrade to High Sierra.
Agree. Nicely said.
Old 09-23-2017, 10:02 PM
Courtlaw Courtlaw is offline
Be aware - I don't think it works with macs that have fusion drives
- Steve
2013 iMac Late model i7 3.5 Ghz quad-core, 24 gigs ram, OSX 10.12.3
PC slave, i7 6700 4.0 Ghz quad-core, 64 gigs ram, SSD drives running VE Pro 7
Multiple external thunderbolt SSD hard drives
UAD Apollo X8, Twin Duo & Quad Satellite Thunderbolt
Townsend Sphere L22 w/ Putnam Mic Collection
LUNA (I have Pro Tools 2020 as well)
Old 09-24-2017, 12:37 PM
Trak Trak is offline
Here is a good link to info the subject.
https://blog.macsales.com/42316-upda...-compatibility
MacPro 3.46 x 12 (2009) 48g, MacOS 10.12.6, PTHDN 2018.7, 2-Avid 16x16 I/Os, Flashed 7950 Video Card
Old 09-24-2017, 08:18 PM
And APFS is a special reason why users need to be careful. If you upgrade to High Sierra and have a flash boot drive it will get upgraded to APFS. You have no control over this. If you have problems due to APFS you can’t roll that back to HFS+ you have to go do a full restore. Many users with MacBook Pros and Mac Pros who are recording to the internal flash drive today should be especially careful.
Old 09-24-2017, 08:49 PM
Eric Lambert's Avatar
This is a major point, and it's not going to get a lot of press from Apple (seeing how they pushed Fusion technology pretty hard for a while), but this could screw with a lot of people, not just ProTools users. But, yeah, also ProTools users. If you have a fusion drive, don't be the guinea pig for High Sierra. I suspect that it could be a particularly difficult downgrade back to Sierra if you pull the trigger too early.
Old 09-24-2017, 08:53 PM
I have a MacPro and MacBookPro. What's the concern with their internal drives? I'd only heard that Fusion owners need to beware (and I thought those drives simply didn't get the upgraded file system and instead stay with HFS+).
macOS Sierra official release date is Sept. 20. How long til Pro Tools is compatible? Justin1524 Pro Tools 12 29 09-11-2016 04:36 PM
