Old 07-01-2014, 02:00 AM
vitolanzafame vitolanzafame is offline
Default Simple trick to audition a track faster?
Hello,
In the past I used a DAW called Reaper which was a simple and pretty great little daw. It had a slider right on the transport control where you could change the speed/pitch of the entire track in real time, which i found really useful to hear what the whole track might sound like a bit faster.
(for me getting the BPM right is gold! - 1bmp can make a world of difference!)
I'm looking for a similar way of doing this in PT. Some one suggested to me that I put time exp/comp plug in on the master track. I can't seem to do this as it is in the audio suite, and i thought you had to select one piece of audio to apply this as an effect. But what i want is to be able to quickly play back the whole song a couple of bpm faster, just to see how it feels.
any ideas?
thanks
Tom
Old 07-01-2014, 05:14 AM
Drew Mazurek's Avatar
Default Re: Simple trick to audition a track faster?
Make all your tracks Tick Based (this can be set as a pref) and enable elastic audio on them, then adjust the tempo and they'll follow.
www.drewmazurek.com
Audition instrument track Dj-Ike macOS 3 11-10-2011 04:09 PM
Simple-ish but Cool Trick (pro tools and logic) TheSetup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2009 09:21 AM
Faster way to place audio in a track? PTGuy Pro Tools TDM Systems (Mac) 7 04-13-2006 05:22 PM
100ata which is faster for track count? Scanners Pro Tools TDM Systems (Mac) 8 09-27-2002 07:30 PM
How can I get faster mouse track speed in OS X? PwAg General Discussion 7 12-01-2001 08:47 PM
