Pro Tools Freezing/Unfreezing Constantly
Hi all,
So I recently updated my PC to Windows 8.1 and since then I've been dealing with a number of issues; many of which you all have helped to solve. I have two consistent problems now that I can't figure out how to fix: -My Pro Tools takes about 6 minutes to load now, which had never happened in the past. It seems to take the most time when loading Xpand!2 - Pro Tools GUI now freezes once a minute for about 20 seconds. If I'm playing back sound or tracking, the sound continues to run, but the screen will freeze and then unfreeze about 20 seconds later. If I'm tracking with a metronome, the click will sporadically shut off and turn on, often displacing the beat. As you can imagine, this makes tracking virtually impossible. There are no commands that seem to cause this more than others; it just continues to occur regardless of what I'm doing. Any advice would be so genuinely appreciated; these issues are delaying my current project immensely. My Sandra Report is listed below and I believe any other pertinent information will show up in my signature. **Edit, my signature isn't showing up, so please see below Sandra Report for other information** Please let me know if I can help in ANY other way. Thanks so much!!!! SiSoftware Sandra ID Host Name : PC Workgroup : WORKGROUP Computer Model : ASUS S500CA Serial Number : D1N0AS2******** Chassis : ASUS Notebook Mainboard : ASUS S500CA Serial Number : BSN1234567********** BIOS : AMI (OEM) S500CA.202 11/20/2012 Intel vPro : 8.01.02.1318 Total Memory : 3.89GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz (2C 4T 3GHz, 3GHz IMC, 2x 256kB L2, 4MB L3) Socket/Slot : FC PGA988 Chipset Memory Controller : ASUS Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 4GB DDR3 SO-DIMM 1.6GHz 64-bit, Integrated Graphics Memory Module(s) Memory Module : LG [Empty] 4GB DDR3 SO-DIMM PC3-12800U DDR3-1600 Video System Monitor/Panel : AU Optronics Generic PnP Monitor (1600x1200, B156XW04 V5 , 15.3") Monitor/Panel : FNI LCD TV (1600x1200) Video Adapter : Intel(R) HD Graphics 4000 (16CU 128SP SM5.0 350MHz/1.15GHz, 32MB DDR3 1.6GHz 64-bit, Integrated Graphics) Video Adapter : Intel(R) HD Graphics 4000 (16CU 128SP SM5.0 350MHz/1.15GHz, 32MB DDR3 1.6GHz 64-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.15GHz, 1.8GB DDR3 1.6GHz 64-bit, Integrated Graphics) Compute Shader Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.15GHz, 64MB DDR3 1.6GHz 64-bit, Integrated Graphics) Storage Devices Hitachi HTS545050A7E380 (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 466GB (C:) SanDisk SSD U100 24GB (24GB, SATA600, 1.8", SSD) : 22GB TSSTcorp CDDVDW SE-208AB (USB2, DVD+-RW, CD-RW, 1MB Cache) : N/A (E:) Logical Storage Devices Windows (C:) : 444GB (NTFS) @ Hitachi HTS545050A7E380 (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) Recovery : 900MB (NTFS) Hard Disk : 350MB (NTFS) Restore : 20GB (NTFS) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SE-208AB (USB2, DVD+-RW, CD-RW, 1MB Cache) Peripherals LPC Hub Controller 1 : ASUS Panther Point LPC Controller Audio Device : ASUS Panther Point High Definition Audio Controller Audio Codec : VIA 8446 Disk Controller : ASUS Panther Point Mobile 6 port SATA AHCI Controller USB Controller 1 : ASUS Panther Point USB xHCI Host Controller USB Controller 2 : ASUS Panther Point USB Enhanced Host Controller #2 USB Controller 3 : ASUS Panther Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Sensors Location : Microsoft Windows Location Provider (Location, Triangulation) Network Services Network Adapter : Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller (NDIS 6.30) (Ethernet) Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Wireless Adapter : Qualcomm Atheros AR9485WB-EG Wireless Network Adapter (802.11n (HT), 72.2Mbps) Power Management Battery No 1 : ASUSTek X502--40 45.34Wh/4.03Ah Operating System Windows System : Microsoft Windows 8.1 Home 6.03.9600 Platform Compliance : x64 Windows Experience Index Current System : 4.7 PC: ASUS S500CA Windows 8.1 Intel Core i7-3517U CPU @ 1.90GHz 2.40 GHz 64 Bit OS, x64-based processor 4GB RAM (Currently 3.89 GB available) Pro Tools 11.0.1 Audio Interface: Tascam US-1800 (Version 2.02 connected through USB 2.0) Last edited by jzaid22; 11-02-2013 at 10:47 AM. Reason: Missing Information |
My first guess/first thing to exclude is a known problem caused by Pro Tools getting confused by a floppy disk drive in your computer (even if you may not actually have a physical floppy drive in the PC -- the CD/red book ripping component in PT 11 keeps trying to access the floppy.). Disable any floppy drive in the BIOS and/or Windows device manager. See http://duc.avid.com/showthread.php?t=344222 and several other threads here.
Other than that make sure you have done every last recommended systems optimization to your laptop. And that laptop is a bit light on specs, e.g. with Intel native graphics, I hope you are not recording to the system drive. And it would be nice to see a faster systems drive, especially if you are using sample based samples. If none of that does this happen with a new session? Trash prefs and databases. Check all plugins are up to date. Try running with all plugins temporarily moved out of their folders (see lots of posts here on how to do that). See the standard trouble shooting steps under the "help us help you..." link above in this web page for more info. Darryl |
Protools 10 constantly freezing (Windows 7) | NickBe | Windows | 8 | 08-26-2014 04:40 PM |
New Pro Tools LE8 Constantly Freezing | Lukehanigan | General Discussion | 1 | 09-08-2009 07:21 PM |
New Pro Tools LE8 Install Constantly Freezing Up | Lukehanigan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-21-2009 10:07 AM |
Pro Tools LE 5.3.2 constantly freezing during playback (Digi002) | sunjitwhy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 05-04-2003 11:57 AM |
G4/500 Freezing constantly!! HELP ME DIGI!! | Mt.Everest | Pro Tools TDM Systems (Mac) | 8 | 08-24-2000 07:20 AM |
