Old 07-02-2013, 07:16 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Main Counter: Font Changed
The weirdest thing happened today... well, a little weird. The Edit Window's Main Counter display's font changed and I don't know how to change it back.
Pro Tools HD 7.3.1
OSX 10.4.11
2 x 2 GHz Dual-Core Intel Xeon
4 GB 667 MHz DDR2 FB-DIMM
(Feet + Frames)
(Timecode)
Any suggestions?
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 07-02-2013, 09:45 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Main Counter: Font Changed
I remember seeing this bug too, but it was years ago. Check avid.com whether there is a point update or a cs update available. Or upgrade to 7.4 which also works with your setup.
Janne
Old 07-04-2013, 07:27 AM
Lightbulb Re: Main Counter: Font Changed
Try starting up your Mac while holding the shift key. Hold the shift key until the Apple logo and spinning gear screen is replaced with a blue screen. This will startup in safe mode and clear out the font cache. Login, restart normally, then see if the font is what you expect it to be.
Protools application font changed!!! Shefi Yishai Pro Tools TDM Systems (Mac) 1 07-10-2013 09:27 PM
Main Counter Question RichrdC Pro Tools M-Powered (Win) 0 02-11-2010 09:53 AM
Main counter mode not switching using "counter" switch bashville ICON & C|24 2 08-07-2009 04:07 PM
Font changed after xp crashed and hmmm! cdrecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-29-2003 04:34 PM
protools font has changed????? Bastiaan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-06-2002 10:00 AM
