Old 06-27-2013, 02:52 AM
blackc7's Avatar
blackc7 blackc7 is offline
Default 192 Digital I/O
The TDIF & AES/EBU connections are suppose to support 8 channels of in and out on one DB-25 connector? I can see 8 channels out or in but not both in and out. I'm trying to find snakes for these connections. (Or am I thinking too hard?)
Old 06-27-2013, 03:53 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 192 Digital I/O
AES carries two channels in one cable so what you need to find is a cable that has 4 male and 4 female connectors. That is 8 i/o both ways.
Janne
Old 06-27-2013, 08:57 AM
Craig F Craig F is offline
and TDIF only connects to another 25 pin TDIF connector, do not try and connect AES to it
Thank you,
Craig
Old 06-27-2013, 09:25 PM
blackc7's Avatar
Ok. DB25 to 4 XLR Male and 4 XLR Female.
Below 192 KHz, AES/EBU carries 2 channels per line, so this snake transmits 8 out and 8 in via the 8 XLR connectors.
At 192kHz sample rate, the 192 I/O is using dual wire transmission. This means the AES snake transmits 4 out and 4 in at 192 kHz. In this case, the connector labeled "output 1&2" is output 1, "output 3&4" is output 2, and so forth.
The 4 XLRF wire jackets are yellow; the 4 XLRM jackets are black, all with appropriate labeling.
Old 06-27-2013, 09:27 PM
blackc7's Avatar
I bought the 192 Digital. But, I think I will need a 192 I/O, also.
Power consumption of the 192IO Digital and HD IO Digital Alécio Costa Pro Tools TDM Systems (Mac) 32 10-26-2014 10:55 PM
Newbie Digital IO question - HD Digital i/o vs 192 Digital vs X-HD mrdosun Pro Tools 10 1 02-16-2012 11:20 PM
If I get PTHD can I hang all my 44/48k digital gear off of a 192 Digital I/O? Jules Pro Tools TDM Systems (Mac) 11 06-21-2002 06:57 AM
Digital Output from 888/16 isn't compatible with Digital Input of TC M2000 & PCM 80 beerbr Pro Tools TDM Systems (Mac) 0 11-02-2000 08:01 PM
Recording 16bit digital to 24bit digital Tips & Tricks 2 03-13-2000 11:37 PM
