Old 03-12-2010, 08:55 AM
chavernac chavernac is offline
Default audiosuite: I Messed up. How do I come back to earlier settings?
HI everyone!
I ve been a Cubase user for years and just switched to Pt
One cool thing in cubase is that when you process a track offline (wich would be the equivalent of the Audiosuite), you can see the historic of all the plugins you have applied to a region. You can change the re-order, cancel, mute, tweak, remove them from the list and kaboooom!! after some processing you have your region just like you wanted.
This makes it easy if you to modify the way if have "permanently" applied plugins to your region....
question: How do we do that in PT?
Old 03-12-2010, 12:06 PM
Bender Bender is offline
Default Re: audiosuite: I Messed up. How do I come back to earlier settings?
You can use the undo function unless you saved the file already.
I like the history function in Cubase too.
Old 03-12-2010, 05:53 PM
If you processed the entire track, the unprocessed region is likely still available from the regions bin. If you process a part of a track, you could use the trimmer tool to drag the end of an unprocessed region across and over the processed region you didn't like. If that isn't making sense, imagine the track is all blue, and you took a section and made it green(your Audiosuite processing). Grab the edge of a blue part and drag it across to cover the green part. Hope it makes sense(its much simpler than I made it sound)
Old 03-15-2010, 08:20 PM
nerd513 nerd513 is offline
try saving a new version of the session before u apply permanent effects to the audio files that way when u mess up u can go back to the original session
Old 03-16-2010, 01:07 AM
Holly73 Holly73 is offline
Another tip: just "duplicate playlist" before doing any audiosuite processing. Like this you can switch back and forth between original and processed version.
To get back some audio that got "overwritten" by the new audiosuite version, you could also try to right-click the region and chose "Matches" from the menu. It is also worth to trying the different "Match Criteria" settings.
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 03-18-2010, 08:00 AM
Great idea!
Playlisting!!!!
Old 03-18-2010, 10:57 AM
Old 03-18-2010, 11:18 AM
You could also open an auto-saved version from before the change, export the original(unprocessed) region(to the desktop would be fine), then open your latest version of the session and import the old region.
Old 03-18-2010, 11:31 AM
I guess it would work...
But I actually, this is not really what i am looking for.
What I had in mind is more the kind of thing like:
"Jeeezzzz I really hit this region way too high with my high pass filter and I realize only 10 days later that i does not fit in the mix... I wish i could undo that and correct my mistake..."
Does that make sense?
Old 03-30-2010, 08:46 AM
to bad u cant trim things once they have been processed any more bad advice?
Skype call settings messed up after using Pro Tools Dominic Gourd Pro Tools SE and Essential (Win) 0 09-13-2012 11:51 AM
PT 10 latest update messed up plugins and settings {anyone help? Iainwh macOS 3 05-12-2012 05:54 AM
I/O settings got messed up for no reason?? Dot Pro Tools 9 3 05-06-2011 07:57 PM
PLEASE HELP!! MIDI Data plays back EARLIER than Performed??? keylowd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-05-2009 04:39 PM
Save Audiosuite Gain settings Karl Engel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-23-2006 08:09 AM
