Old 12-07-2007, 05:29 PM
JustparaDOX JustparaDOX is offline
Default I Can Not Open or Uninstall Pro Tools M Powered 7.3 on Vista
I Can Not Open or Uninstall Pro Tools M Powered 7.3 on Vista. I installed it as stand alone but I have the Moble Pre and so I should have done the one with hardware but now it won't let me open it, its asking for an iLok that I don't have and when I try to uninstall it, it says that protools is already installed and I have to uninstall it but thats what I'm trying to do uninstall so I'm stuck.
Vista sucks. I set it up under the option to open the file on Windows XP SP2 mode.
Can someone please help me get this fixed? Thank you very much
Old 12-07-2007, 05:55 PM
spkguitar's Avatar
Default Re: I Can Not Open or Uninstall Pro Tools M Powered 7.3 on V
Try the PT Uninstaller Utility.
Also, the only version of Pro Tools that is compatible with Vista is Pro Tools 7.4.
Another also, if you don't have an ilok, then how do you have MPowered? An ilok is required to run the software, and it comes with one when you purchase. I'm just a little confused on that one.
Old 12-09-2007, 06:56 PM
Default Re: I Can Not Open or Uninstall Pro Tools M Powered 7.3 on Vista
I have the M Audio MobilePre and it says you don't need the iLok...
Old 12-09-2007, 10:42 PM
Jordan Maldonado Jordan Maldonado is offline
have you registered your copy of pro tools?
i bought 7.3 and couldnt install it either.
but i went to the digi website, registered and they automatically kicked me an upgrade email.
do so and download the 7.4 upgrade and everything should work fine.
and your copy should have come with an iLok....
Old 12-10-2007, 07:29 AM
spkguitar's Avatar
You don't need the iLok to run the MobilePre, you need the iLok to run the Pro Tools software.
It is a fact. Pro Tools MPowered requires an iLok to run. Period.
Old 12-11-2007, 12:57 PM
You do not need iLok to run Pro Tools M-Powered Academic 7.3.x with M Audio Mobile Pre USB Win - http://www.digidesign.com/index.cfm?...5&itemid=24381 or http://www.digidesign.com/index.cfm?...d=100&eid=3178
You only need one of these M Audio Interfaces
M-Audio Interface
Audiophile 192
Audiophile 2496
Audiophile USB
Delta 1010
Delta 1010LT
Delta 44
Delta 66
Fast Track Pro
Fast Track USB
FireWire 1814
FireWire 410
FireWire Audiophile
FireWire Solo
JamLab
M-Audio Black Box
M-Audio Ozone
MobilePre USB
NRV10
Ozonic
ProFire Lightbridge
ProjectMix I/O
Torq Conectiv
Transit
M-Audio ProTools M-Powered 7 w/MobilePre Bundle USB Academic Win
Here is the info link: http://www.journeyed.com/itemDetail.asp?ItmNo=52637994
ProTools:
Minimum System Requirements (PC)
Digidesign-qualified M-Audio System
Digidesign-qualified computer running Windows XP
Old 12-11-2007, 02:54 PM
spkguitar's Avatar
That's the first time you have said anything about having MPowered Academic. Your original post said nothing about that; you only mentioned MPowered.
It really doesn't make any difference; neither one will run on Vista.
Old 12-15-2007, 09:32 AM
ledoux ledoux is offline
I'm had PT Academic 7.3 and received a msg from M Audio offering an upgrade to M Powered 7.4. I loaded it into my Dell XPS laptop with Vista and it works fine. Does require iLok and some M Powered hardware though.
Pro tools 8 m-powered and vista 64 christodoulidesd Pro Tools M-Powered (Win) 60 06-23-2009 01:47 AM
pro tools 8 m- powered on 64 bit vista? geoglove General Discussion 1 05-27-2009 07:01 AM
Cannot Uninstall Pro Tools 7.1 in Vista UGH!!!!!! snowmaker2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-22-2007 04:04 PM
Pro Tools 7.3.1cs2 ill not open.. uninstall.. nothing..?? BlueWeed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-22-2007 10:23 AM
Pro Tools 7.3.1cs2 ill not open.. uninstall.. nothing..?? BlueWeed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-20-2007 07:31 PM
