Old 11-02-1998, 07:41 PM
Echo studios Echo studios is offline
Default USD setup compatibility with PT 4.2.1 NT
When approx. do you think the USD setup will be implemented inside PT 4.2.1 NT software?
Thanks for the update!
-dan
Echo Studios
PT HDX2 / Ultimate / D-Command ES 24
MP Dual 3.66mhz ( 6-Cores) / 128GB / SDD 8TB
OSX Sonoma 14.4
Dan Desilets
Mix/Mastering Engineer, Guitarist, Composer
New Website live @ www.yuccamusic.ca
Old 11-02-1998, 08:16 PM
Digi Engineering Digi Engineering is offline
Default Re: USD setup compatibility with PT 4.2.1 NT
I don't have a date on that yet. What specific function were you needing the USD setup app for? Most of the USD parameter are set-up by Pro Tools for you.
-Mike Rockwell
Old 11-02-1998, 08:26 PM
Ok.
Well, I have no specific functions in mind just that if I actually get the USD interface and connect it to the serial port of my d24 card and then launch PT4.2.1 NT, will it recognize the USD and will I be able to use all the sync features of it without any compatibilities issues?
Thanks again for the cues.
-Dan
Echo studios
OSX Sonoma 14.4
Dan Desilets
Old 11-02-1998, 08:27 PM
Ok.
-Dan
Echo studios
OSX Sonoma 14.4
Dan Desilets
Old 11-03-1998, 08:54 AM
You should be able to perform all the sync features of the USD from PT with a few exceptions and most of those are available from the USD front pannel.
-MR
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 02:44 PM
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 2 11-17-2010 11:05 AM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
OMS Setup: Interface Req'd? Setup referrences? eltornado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-19-2000 04:17 PM
