Old 11-01-1998, 06:02 PM
Echo studios Echo studios is offline
Default Question about Disabling PCI parity in BIOS
Ok heres a question. What exactly do u mean by disabling PCI parity?
In my BIOS, which is an Award, I dont have that function. Is that memory-related? if so, it is already disabled because of the ECC- and non-ECC (memory error correction & parity mode) standard.
thanks
-dan
Echo studios
PT HDX2 / Ultimate / D-Command ES 24
MP Dual 3.66mhz ( 6-Cores) / 128GB / SDD 8TB
OSX Sonoma 14.4
Dan Desilets
Mix/Mastering Engineer, Guitarist, Composer
New Website live @ www.yuccamusic.ca
Old 11-02-1998, 09:44 AM
Digi Engineering Digi Engineering is offline
Default Re: Question about Disabling PCI parity in BIOS
If there is no setting for PCI parity in your Bios then your motherboard probably doesn't support it. This means that it is off. You will know if parity is set incorrectly because either your machine won't boot or the cards will not be recognizedl.
-Mike Rockwell
Old 11-03-1998, 12:36 AM
Thanks a lot. Everything is working fine!
-dan
Echo Studios
OSX Sonoma 14.4
Dan Desilets
Win XP: BIOS disabling or Device Manager disabling ?? mandal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-23-2007 03:11 AM
Disabling multicore support in BIOS Dep Affect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-21-2007 06:00 PM
Bios question Mike Emerson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-06-2002 04:18 PM
Disabling PCI Parity T-Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-02-2001 12:52 AM
Bios question mixer911 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-29-2000 02:56 PM
