Old 05-18-2022, 02:36 PM
chapmanpondmusic chapmanpondmusic is offline
Default cloud project count
the project in the cloud number is stuck on 3/3 on the create page of the dashboard and on the my products page on avid. i only have one blue colored project. once i close pro tools first and then restart it the percentage used changes as i work on a project or remove it from the cloud. what can i do? Can i contact Avid and get it fixed or is this a symptom of Pro Tools First being discontinued
Old 05-18-2022, 03:01 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: cloud project count
Sorry for the trouble. We can reset your Avid Cloud, but make sure you export audio from any Projects if you want to later import them into a new Project (mute or solo if desired to create individual multitracks for mixing then... File > Export > Bounce Mix).
linkedin
Old 05-25-2022, 01:40 PM
yes please reset my cloud. my dashboard says i am using 2/3 under the 'create' tab. but none of my projects are blue. so if you can reset i won't loose anything. and if i can somehow get a confirmation that would be great. thank you
Can't open cloud project madspettereriksen Licensing & Accounts 2 06-26-2021 02:51 PM
Why is backup to cloud option disabled for project already in the cloud? BLG Pro Tools | Intro Discussion 1 02-21-2021 01:12 PM
Cannot open Cloud project Peters86 Pro Tools 2020 2 05-07-2020 08:34 AM
Protools First Cloud project headlap Pro Tools 12 2 12-11-2018 12:03 PM
Always 99% cloud even an empty project ... babaorum Pro Tools 2018 17 07-19-2016 09:18 AM
