Old 05-17-2004, 07:54 PM
keithl keithl is offline
Default how to put transport window inside edit window?
I remember seeing a screenshot of somebodys edit window and I believe the transport window was "inside". I looked inside the preferences and searched the duc to no avail...
Does anybody have any idea how to do it.
Keith
my web page
(BTW: My first experience with the 002 was Saturday and even though I KNOW I did not scratch the surface(!), the unit/PT flat out rocks...)
Old 05-17-2004, 08:19 PM
cruisemates cruisemates is offline
Default Re: how to put transport window inside edit window?
You mean other than just dragging it in there?
- but the second mouse gets the cheese
Old 05-17-2004, 08:30 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
I think you're looking for This from Nikki-K you'll find her description as follows:
Hmmm...
I work in an odd fashion perhaps
I dont use the Edit or Mix window maximized, ever.
I hit the maximize button for the PT window itself, then adjust the size of my Edit window to fill the entire PT window.
Then, bring up the Edit window on top of the Edit window, and adjust full to bottom and sides, and then right up under the Edit window "header" that has the transport window "basics" showing.
Then, I use one of the "thumb buttons" on my Intellimouse explorer to swap between the two windows. (Intellipoint 4 software, with the "enable application specific assign" checked, and PT setup for my personal settings).
Yeah, two monitors would be nicer, but I keep finding better things to spend $$$ on
Once I have the windows set like that, save session and reopen has had them in same spot everytime so far with 6.4.
screenshot
Unless of course you are just referring to the new edit window in 6.4 which has the transport embedded already
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Booyah Booyah is offline
This a new feature of 6.4 if your interested, the transport buttons and part of the top of the edit window.
Old 05-17-2004, 08:48 PM
bizeee bizeee is offline
Protools 6.4 is great. 6.4 also remembers when mix/edit windows are maximized within the session.
DIGI002/XPpro/DellINSPIRON8500/ProtoolsLE6.4
Old 05-17-2004, 09:38 PM
hmmmm....I guess I was trying TOO hard to research and not doing the old common sense "try to drag it in there!"...
Thanks for the help guys!
Old 05-18-2004, 05:54 AM
Camilo Toledo Camilo Toledo is offline
Is there a way to get it on the mix window, besides the way it was shown above, and the regular "floating transport window".
Camilo Toledo
Old 05-18-2004, 09:32 AM
FatBelly FatBelly is offline
You will have to adjust the screen like the screen shot from Nikki K if you want the embedded
transport controls in the MIx window.
The place where you turn this option on and off is under the Display Tab.
Drop down to Edit Window Shows and you should see the option for Transport View.
I hope this is what you were talking about.
FatBelly Slim
FatBelly Slim
Oh no, not the sprinklers again.
Old 05-18-2004, 10:14 AM
millicent frndly millicent frndly is offline
Alright here's one. I hardly use the transport at all... only to toggle on/off pre/post roll. Is there a way to get those functions into the Edit/Mix window? (is it there and I'm missing it?) Or are they shortcut keys for this? I've searched the manual and sheets and can't find anything about it. Thanks.
chris
Digi 001/WinXP Home
A7N8X Dlx
AMD 2500+ Barton
1024mb DDR PC3200
Maxtor 40gb System and 60gb Audio drives
www.millicentfriendly.com
Old 05-18-2004, 06:47 PM
You can Alt click before and after the insert point to set pre and post roll... or drag the flags in the timeline.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
How to: Switch between sub-windows: Midi editor inside of edit window bashville macOS 3 10-20-2012 07:59 PM
Transport on top of edit window stevedresser83 Windows 1 01-25-2012 08:08 AM
Pro Tools 8 edit window wont fit - transport is cut off newdayworld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-20-2010 04:29 PM
Transport Window and Color Selection window lost cd_audio_mix Pro Tools TDM Systems (Mac) 6 11-26-2006 10:58 PM
