Old 07-21-2002, 05:15 PM
John H John H is offline
Default Will I be able to assign control knobs on a midi keyboard to automation ?
I've been looking at getting one of the evolution USB midi keyboards later in the year and the models I'm looking at either have a 49 Keys and 14 assignable controllers or 61 keys and 16 controllers.
I'm thinking of going for the 61key version unless my inpatience makes me buy the cheaper of the 2.
I plan on using most of the control knobs for realtime automation control for plug-ins and panning while leaving a few for synthesis (cut off, resonance ,ADSR)
If I've read up on it correctly, the motormix needs a midi channel to itself, does this mean with other controllers I wouldn't be able to use the same midi channel for midi control as I would for automation ?
It'd be great to just use a strip of knobs on a controller keyboard for both midi and automation control.
Old 06-16-2010, 06:25 AM
Robbing Hood Robbing Hood is offline
Default Re: Will I be able to assign control knobs on a midi keyboard to automation ?
anyone got the answer to this?
Old 06-17-2010, 01:57 AM
Darney Darney is offline
You should be able to set this up using the "Learn" command in the setup operation for midi. See p. 900 of the PT User Guide.
“What fresh hell is this?” - Dorothy S. Parker
Assign Samples To Midi Keyboard. imperialcarter macOS 1 02-08-2012 10:29 PM
Faders and FX automation by Midi keyboard AmitSadras Pro Tools 10 4 01-22-2012 10:19 AM
MIDI Keyboard Fader to Write Automation? Max H. Post - Surround - Video 3 10-30-2011 05:20 PM
Korg microKontrol - Assign Faders/Automation Control Over PT sleazedc MIDI 9 09-27-2008 06:51 PM
MIDI messages for remote control of faders/knobs Hi Stakes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-30-2004 11:26 PM
