Old 05-07-2015, 12:58 AM
hoeglund hoeglund is offline
Default Eucon Preferences, cannot add applications
Hi all,
After updating to v3.2.2 (inkl. successful firmware update of the Artist Mix) and Yosemite it doesn't work for me to drop any applications onto the Eucon preferences pane, anything I drag&drop there just "bounces back".
I've added Read&Write access to several system/user library and preferences folders for all users without any luck
Anyone?
Thanks
Old 05-08-2015, 01:51 PM
Default Re: Eucon Preferences, cannot add applications
As a workaround I added the apps manually in the EuControl preferences file com.euphonix.EuConSystem.plist using the plist editor "Pref Setter". Add the identifier, name, path, midi ports, and protocol under the node "EuCon Applications".
All's working fine again.
OS X 10.10.3, UAD-2 Apollo Quad, Pro Tools 11, HD 9
Old 05-08-2015, 03:38 PM
recur recur is offline
I've got the same issue, however no amount of hacking the preferences .plist is making any form of success for me.
Have purchased an ASC to get help with it but the IVR gobbled up the ASC and redirected me to a Japanese voicemail and hung up on me.
Seriously, how hard would it have been to test this prior to release? 6 months after Yosemite gets released we get the driver in a non functional form. Pretty poor form.
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
Mac: Euphonix Preferences panel drops non-eucon apps avezeau Artist Series 8 11-28-2011 07:07 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
Using your DAW for other applications? NoiseRoom macOS 3 12-09-2010 05:22 PM
