Route two instrument tracks to one midi track ?
I have two mono tracks (panned hard left-right) with one instance of velvet on each. Im trying to route these two instrument tracks to one midi track so I can play and record stereo on the midi track.
Is this possible ? |
Re: Route two instrument tracks to one midi track ?
If you use a MIDI track, you can assign multiple outputs for MIDI just like audio. So MIDI track and two Auxes with your VI in each. Then select your MIDI track output and then Start-click or ctrl-click (whatever it is) to add the next Aux VI to the output of the MIDI track. See if that works - I'll have to try it later.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Great. Thanks. |
I know this post has a while now, but I was looking for the same thing (having a single midi channel to play several instruments at the same time) and I found the answer in this post. Francisco
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
midi track record turns off all other midi/instrument tracks delay comp | holyspicoli | Virtual Instruments | 4 | 07-18-2013 06:14 AM |
Controlling multi instrument tracks with single MIDI track? | MotifMan | Virtual Instruments | 10 | 07-21-2012 01:08 PM |
2 instrument tracks each controlled by different MIDI input/instrument | Midimax | Pro Tools M-Powered (Win) | 0 | 03-20-2012 03:10 PM |
MIDI Tracks Versus Instrument Tracks. VERY Confused. | Rick540 | MIDI | 8 | 12-04-2008 11:04 AM |
Output to speakers from 2 soundcards + how to get MIDI track to route to audio | LTEtabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-09-2001 01:07 PM |
