Old 08-19-2019, 11:18 AM
sixpointmusic sixpointmusic is offline
Default Importing DNxHD video, aspect ratio stretched.
I imported this DNxHD video(original size 1080x540, =16:8) to my session but looks like Protools stretched the video to 16:9 automatically.
Is there any way to make Protools keep the original size?
*The original video I got from my client was mp4, H264, 1080x540.
*When I import this original mp4, Protools keeps the original size. but mp4 doesn't play well.
*I converted this mp4 to DNxHD using Quicktime Pro. Setting is Avid DnxHD Codec, 1080p/23.976 36 8bit, size custom 1080x540.
*Converted video says 1080x540 and if I open on Quicktime, it looks 1080x540.
*I tried MPEG Stremclip too, same result.
Is there any setting I'm missing when I convert?
I wanna use DNxHD because it plays much better than mp4 even though the file size is much bigger.
Any idea/advice would be appreciated. Thanks!
My system:
Mac Pro 5,1 (Mid2010) 2x2.66 Ghz - 6core Intel Xeon
Memory:48GB 1333Mhz DDR3
OSX 10.10.5
Prootols 12.5.0
Old 08-19-2019, 12:03 PM
BScout BScout is offline
Default Re: Importing DNxHD video, aspect ratio stretched.
When you do the convert, choose to maintain original proportions and pad/letterbox as necessary (both options) and then use a standard dimension (1280x720). This will insert black bars at the top and bottom to maintain the aspect ratio.
DNxHD/DNxHR do not actually have "custom sizes" in their specs (you can look up their tables)
Old 08-19-2019, 01:24 PM
MatzeHD MatzeHD is offline
Yes, i as wondering that DNXHD supoort this weirdly resolution?^^
Old 08-19-2019, 02:21 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
DNxHD cannot support weird resolutions. DNxHR is fairly flexible with custom sizes.
Converting to DXnHR could give you that option. FWIW Resolve Studio definitely does flexible size DNxHR exports. I am not sure that Resolve Free does.
Andrew
Old 08-20-2019, 09:24 AM
Thanks everyone!
I did letterbox and 1280x720 and worked! Thanks BScout.
I didn't have DNxHR option in my QTpro or Mpeg stream clip but anyway, very happy here.
Thanks again.
HTML code is On
Different Aspect-Ratio of video in the same track critictalk Tips & Tricks 0 06-03-2014 07:34 AM
Video Import Aspect Ratio Madness postmike Pro Tools TDM Systems (Mac) 9 04-23-2010 08:20 AM
Video Aspect Ratio Question Peter Miller Post - Surround - Video 5 10-02-2009 01:30 AM
Video Aspect Ratio Question Peter Miller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-25-2009 06:08 PM
Video aspect-ratio. lode Post - Surround - Video 10 02-09-2007 05:39 PM
