002 rack as stand-alone Preamp
Can you use the 002 rack as a standalone preamp like the 002? If so, then can you still monitor the signal through the headphone output when in standalone?
I am trying to put together a small home studio as well as live rig on a budget, and am hoping to use the 002r as a preamp to my rack effects on stage, as well as an audio interface at home. Would this work ok? |
Re: 002 rack as stand-alone Preamp
no the 002r like the 001 can only be used with a cpu attacked, at least I never came across anything else.
only the 002 can be used as standalone mixer. the $1000 difference MUST hide somewhere. regs
last: PT11.3.1 |
Yes you can ( sort of)
If you plug someting in to the alt-src Input, this can be monitored without opening protools. Simply select the alt-src to Mon button on the front. I do this with my keyboard so I can practice with the computer off. When I want to record this signal, I simply select alt-src to 7-8 and then use Input 7-8 in PT.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Original Mbox as stand alone mic preamp | finkbmx | General Discussion | 6 | 11-13-2016 04:12 AM |
8 channel audio interface and stand alone preamp | alidav | macOS | 18 | 03-15-2014 08:32 AM |
888 24 Stand Alone Preamp? | mikeofsines | Digidesign Hardware & Software | 2 | 01-12-2010 10:12 PM |
Can Firewire 410 stand alone as a preamp? Sleep? | ktommy | Pro Tools M-Powered (Mac) | 2 | 02-08-2006 09:24 AM |
002 Rack stand alone? | getfunkynow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-27-2004 11:59 PM |
