Parameter "dump"
Hi there.
Is there a way for me to dump/record all parameters from a Moog Sub37 as they are "right now"? Something like this: - select a preset - tweak it to an initial state for the start of the song - dump/record it onto a MIDI track - record the performance Thanks.
Re: Parameter "dump"
Yes. Page 37 of the Sub37 manual for current Buffer (current settings of sound) and Sequence (current settings of sequence) Send. You need to make sure you don't have Sysex filtered in Pro Tools or your MIDI interface. Then it is just a matter of putting Pro Tools into record and then dumping. On playback, it'll overwrite whatever is currently in the Moog's buffer (so if that setting isn't saved, you'll lose it) but only puts it in the temp buffer.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Perfect! Sysex buffer send is exactly what I wanted. Thank you.
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" | EdgarRothermich | Pro Tools 12 | 2 | 10-04-2017 02:18 PM |
Change Track View "vol" or Pan parameter only on selected Tracks | joachim | Tips & Tricks | 0 | 12-03-2015 07:05 AM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
AAAGGHHH!!! Won't Bounce!! "The Parameter Is Incorrect"?!??! | The Zone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-30-2002 09:23 AM |
