Old 11-10-2010, 07:25 PM
gerarddaly gerarddaly is offline
Default Protools 9 - Audio Interface to replace Mbox
Hi, I'm running Protools 9 on a PC with Windows 7. I sold my mbox as I didnt like the pre amp. I bought a Golden Age Pre 73 (like Neve 1073). I want to record from my Pre 73 pre amp direct to Protools 9 on my PC. Most of the audio interfaces on the market these days, seem to come with pre amps and mic inputs (which I already have with my Pre 73 pre amp). Can anyone recommend an 24 bit 96 Khz audio interface that just has minimum inputs, and includes a 1/4" balanced line input?
Old 11-10-2010, 07:44 PM
rickdog rickdog is offline
Default Re: Protools 9 - Audio Interface to replace Mbox
The Firestudio Mobile has six balanced line inputs:
http://www.presonus.com/products/Det...x?ProductId=58
Is also 96k compatible.
Old 11-10-2010, 09:01 PM
AxeDye AxeDye is offline
RME Fireface 800 is nice, Motu has some nice producs
RME
Motu
Focusrite
those three re pretty solid. all interfaces have those line inputs either built into the pre input with the option to switch between mic/line/inst. mode and some have the pre on the front and line on the back of the interface.
Old 11-10-2010, 09:28 PM
Thank you AxeDye- appreciate your help...
Cheers,
Gerry.
Old 11-10-2010, 09:29 PM
Thank you Rickdog- appreciate your help...
Cheers,
Gerry.
Old 11-10-2010, 09:30 PM
ddjembe mutombo ddjembe mutombo is offline
uh... correct me if I am wrong... but couldn't you have just run the pre through the line in jack on the mbox. Wouldn't that have bypassed the mbox preamp?
Old 11-10-2010, 09:46 PM
nst7 nst7 is offline
I think the line in on the old Mbox still ended up going through the preamp, which may have been an issue for him.
Old 11-10-2010, 11:49 PM
Yes you are right- I can totally bypass the pre on the mbox by plugging my golden age pre 73 into the fx inserts on the mbox 1- only probalem is, Avid have decided that you cant use the mbox 1 with PT 9 (but you can use hardware from any other brand or company!
[IMG] code is Off
Alessis Multimix8usbfx interface and Mbox 2 interface with Protools 11 Majorpain7 Pro Tools 11 0 01-06-2014 07:40 PM
Help! Best outboard pre-friendly PT audio interface to replace 003? tj7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 11-04-2011 08:27 AM
interface to replace Mbox 2 with analog summing and more ins and outs? JWW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-08-2010 09:53 PM
Possible to replace the Mbox with other interface? Robert Mattsson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 10-06-2005 12:14 PM
New LE interface to replace 001? Kirkland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 05-21-2003 11:26 AM
