Audio Zoom In and Audio Zoom Out Shortcut
5 minutes on Google hasn't helped so now I must ask this here:
Is there a shortcut for increasing or decreasing the vertical zoom level of waveforms in Pro Tools to see really quiet passages?
iMac Pro 3.0GHz 10-Core • 64GB RAM • SSD for OS and audio • MacOS 10.13.3 http://www.mysteryroommastering.com/ http://www.justincarlperkins.com/ Last edited by Jperkins; 02-04-2018 at 04:35 PM. |
Re: Vertical Waveform Zoom Shortcut
the shortcut is
cmd+option+ [ or ] for vertical zoom and cmd + [ or ] is the horizontal zoom |
To be clear, I'm trying to zoom in the waveform so that it becomes inflated so I can view low level audio stuff. I'm not asking to make the track larger. Audio Zoom In and Audio Zoom Out is what it's called when I do it manually.
iMac Pro 3.0GHz 10-Core • 64GB RAM • SSD for OS and audio • MacOS 10.13.3 http://www.mysteryroommastering.com/ http://www.justincarlperkins.com/ |
macOS Sonoma 14.2 • Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM • Pro Tools Studio 2023.12, RME Babyface Pro |
Re: Audio Zoom In and Audio Zoom Out Shortcut
Then T and R, as zoff says, to zoom in and out. If you want to enlarge vertically, you have to also enlarge the track which is ctrl+ up and down arrows.
I'm talking about increasing the size of the waveform, similar to how Clip Gain might do but without affecting the audio level.
I'm aware that R & T are used to zoom in and out but this is not what I'm referring to.
See the screen shot.
And the other setting of command+ square bracket does the other part of that section of tools: Horizontal Zoom In and Out. That is why they are one modifier key away from each other. |
Set your zoom presets . Upper right corner of the edit window is the waveform and midi enlarge buttons. Left and right click to get the size you want then save it as a zoom preset.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Try Alt+Shift+Scroll Wheel (PC).
I can not make vertical zoom Shortcut | cmbourget | Windows | 8 | 05-08-2015 04:35 PM |
Vertical zoom to show default waveform height (Audio) with D-Command ? | Hanswurstlsepp | ICON & C|24 | 0 | 06-30-2011 03:55 AM |
Vertical edit zoom shortcut, where / what is it? | Strebor24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-29-2010 06:15 PM |
Waveform vertical zoom thing... | Kuba Pietrzak | Post - Surround - Video | 6 | 01-17-2008 12:31 PM |
Vertical single waveform zoom - not working | sonuslab | Pro Tools M-Powered (Win) | 7 | 10-19-2006 05:34 AM |
