Old 03-18-2014, 08:23 AM
stargazer stargazer is offline
Default Playlists order in Loop Record
Quoted from an old thread:
http://duc.avid.com/showthread.php?p...50#post2141850
Originally Posted by Alden View Post
I am on PT8 HD, MacOS.
So, let's say i'm recording 4 takes of the same section in loop recording mode. I have "automatically generate new playlists when loop recording turned on."
So, after I finish my takes and I open the list of playlists, or expand out the playlists to lanes, my takes are now ordered 4, 1, 2, 3. (with four being on the main playlist and 1,2,3 following.)
Is there still no way to get the order 4, 3, 2, 1?
I often do multiple passes in loop mode.
So I end up with, for example, from top to bottom:
13, 9, 10, 11, 12, 8, 5, 6, 7, 4, 3, 2, 1.
It would make more sense to have all playlists in chronological order, I think.
Dragging playlists is an option, but it's an extra step, and also buggy.
Sometimes when I drag a playlist to change the order within a track, it ends up on another track.
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 03-18-2014, 10:28 AM
joachim's Avatar
joachim joachim is offline
Default Re: Playlists order in Loop Record
I would vote for that on ideascale,
and while they are at it, they also could fix the wrong clip rating (http://duc.avid.com/showthread.php?t=346563)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Use loop record with auto-created playlists a lot? This might help you. clutch Tips & Tricks 6 11-07-2013 09:54 AM
Midi loop record playlists / comping east MIDI 6 10-07-2009 04:37 PM
Several songs in same session want to change order including playlists Santo Pro Tools M-Powered (Mac) 0 09-01-2009 08:34 AM
HELP: loop record, playlists, comping megahurt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-22-2009 09:29 PM
Auto Playlists in Loop Record? John Pisciotta Pro Tools TDM Systems (Mac) 2 03-23-2005 05:58 PM
