Old 03-11-2007, 05:11 AM
KamilFX KamilFX is offline
Default 96kHz????????
Hello
Dear Digi.
There is a next product in your offer: Digi 003 and there is no 96kHz ADAT. Why????
Is it possible to record something in 96kHz thru ADAT (4 channel instead of 8).
I would like to record drums in 96kHz and I need 12-14 tracks but with Digi i have only 10 - 8 analog channel, 2 S/PDIF channel.
Thank for answer.
Old 03-11-2007, 10:18 AM
lemix's Avatar
lemix lemix is offline
Default Re: 96kHz????????
KamilFX,
Why ?
We don't know, although there could be some licensing issues involved with the inclusion of an S/MUX (Sample Multiplexing) compliant optical port.
BTW, none of Digidesign's hardware supports that function.
You can always use a different platform to record, or stay @ 48kHz...
happy tooling
a
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 03-12-2007, 02:23 AM
And...????
Old 03-12-2007, 06:58 AM
lemix's Avatar
And...????
and what ?
I've given you my guess as to "why"...that was your question..no ?
a
cheers,
Andrew
Old 03-12-2007, 10:30 AM
JFreak's Avatar
JFreak JFreak is offline
ADAT specification goes up to 48k, no more. Digidesign is sticking to the spec.
Janne
Old 03-12-2007, 10:33 AM
spkguitar's Avatar
However, several of the M-Audio interfaces are capable of S/MUX-ing the ADAT inputs, so you might want to check those out for use with Pro Tools MPowered. I'm not positive that they work in Pro Tools that way, but if that's what you're after, it's worth some investigation.
Old 03-12-2007, 10:47 AM
jbr jbr is offline
Also, the Presonus Digimax FS is cabable of 96k ADAT(Dual SMUX)
http://www.presonus.com/digimax_fs.html
Old 03-12-2007, 01:47 PM
O.K.
Thanks everyone for answer.
I hope that in next generetion of DIGI we'll be able to record in 96kHz from ADAT with SMUX
Thank You
Old 04-04-2007, 07:43 PM
Sherbert99 Sherbert99 is offline
Yeah I was pumped thinking the 003 would support 4 96k i/o's what a let down.
I don't see any useful reason for me to go from m-audio
1814 to the 003 since I use 96k.
You can look into the m-audio 1814 it supports s/mux. I have been using it. It's not to bad.
96khz jglunt2112 Pro Tools M-Powered (Win) 3 04-01-2015 04:27 PM
24/96khz with mix and 888/24 i/o taiazeez Pro Tools TDM Systems (Mac) 0 01-28-2006 05:16 AM
96khz on PT LE 6.7 nickster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-10-2005 03:20 AM
96khz Is it necessary? Sharritan Tips & Tricks 10 10-03-2004 02:10 AM
From 96Khz to CD Compression Records Tips & Tricks 1 09-07-2000 07:51 PM
