Pro Tools First Won't start on initial start up
Does anyone know what this means? I can't start the program after install. Also, what is a copy button? Do they mean the copy command? I can't copy or paste anything into the window that wants to send a message to Avid. I have done the usual things to correct this including an NVRAM reset. Nothing works. The program won't start and continues to give me this error.
Assertion in "Volumes/Development/Code/222439/ProTools/App/Document/UProToolsWindowPresetMgr.cpp", line 250. (Use the Copy button to copy this message to the clipboard.) Last edited by tsmchenry; 03-04-2018 at 04:46 PM. |
Re: Pro Tools First Won't start on initial start up
As for your error, what kind of audio interface are you using? Are the drivers up to date and does it work in other programs? Are you using an admin account on your system? Give us a little more info and hopefully we can help. |
Thanks for getting back with me, regarding the interface, I'm using a simple PreSonus Audio USB Audio box. Yes, it works with my other DAW which is Digital Performer 9. When I start the program, after initial install, PT won't open at all. The screenshot I uploaded is all you see. I've tried starting the program both with and without my interface hooked up. Could this be a clocking issue? I have lots of stuff hooked up to my computer and at least one of them demands a 48k clock while everything else in my system defaults to 44.1. I had issues with DP crashing when I first installed it over this issue, but I was able to work it out by not allowing DP to access the 48k device when it starts. I've noticed that PT automatically sets up I/Os based on whatever is recognized by my sound card. DP allows you to choose your I/Os, master clock, project sample rate and bit depth before the audio engine loads. Is there a similar setup procedure for PT?
This certainly could be. You may want to try just one sample rate until you get things going. Also, try holding down the N key while PT starts. This forces a hardware refresh, which may get you past the error and to the point where you can select your interface.
BFD2-Initial Groove start is noisy. | Broadsneakers | Pro Tools M-Powered (Win) | 1 | 05-29-2012 09:31 AM |
Lion Pro Tools SE won't start on one account, but start on another | AndrewGalas | Pro Tools SE and Essential (Mac) | 2 | 12-15-2011 11:06 AM |
Downloaded PT 8 and it wont start PT logo moves but doesnt start????????? | protonneutron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-30-2008 03:25 PM |
Can't start PT LE 5.3.1 on initial install - XP | zagood | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-12-2003 05:12 AM |
Pro Tools 5.1 Session Start—Record Start Interval | Avid | Pro Tools TDM Systems (Mac) | 4 | 04-18-2001 08:27 AM |
