Re: Waves CLA-76 and CLA-2A problems
Digital Zipper.....
Weird I know, I will post a video later.
Avid Audio Engine and plugin setting are all in the prefs. I've fixed similar issues to this before by pref trashing. Certainly your first point of call. Otherwise continue with the virtual switch cleaner Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
Seriously, try to automate a parameter. Does it still make problems during playback then?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Very good guys, appreciate the info...will do asap and report back.
Cheers
It is your duty, that's going to have millions of hits and it's also part of the history!
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
FYI
Dear Daniel, Thank you for contacting Waves Tech-Support. Changing parameters during playback might introduce some momentary artifacts. With CLA-2A this would happen only with the Gain knob. With CLA-76 this happens with both the Input and Output knobs. This is a known issue which would be addressed in the future. No ETA at the moment. Let me know if there's anything else I can assist you with. Best Regards, Waves Support
WOW !!!
SomWaves are saying "don't touch" the plugin parameters while playing That totally makes it unusable as you would have to start and stop every detailed change in settings to hear .. blaaah #wavesstrikesagain
If Drew hadn't have made that joke, someone else would have. Most likely me!! I thought the same thing as I was reading your post.
At least it's a known issue and Waves did say they are working on it. I'd consider that good news. |
I've been running those for years and never had such an issue. Maybe you're due for a system reboot - you know, a fresh start.
WombatStudio.Org Digital Recording, Mixing and Mastering in Gibbsboro, NJ USA "It's not the gear ... it's the ear" |
Waves 7 PAZ problems in 8.0.3? | bashville | Pro Tools TDM Systems (Mac) | 2 | 01-12-2010 01:53 AM |
Waves 7.0 L1+ problems | ilovemyssl | Pro Tools TDM Systems (Mac) | 11 | 11-07-2009 06:52 PM |
WAVES IR1 - anyone tried it having problems !!! | hokuspocus | Pro Tools TDM Systems (Mac) | 5 | 03-01-2004 05:07 AM |
Waves REQ problems | johnedmonds | Pro Tools TDM Systems (Win) | 2 | 11-04-1999 07:35 AM |
Waves problems!! | stefan. | Pro Tools TDM Systems (Mac) | 0 | 10-15-1999 02:47 AM |
